Rust on the inside of the door
nakota
What would be the best way to tackle this rust? I need to do something with it before it gets worse and eats my doors.
Here's some pics -
Oh, and the holes aren't plugged, can't remember if you can see them from the pics. Thanks!
4xdog
Rust is always much worse than it looks. You might be surprised when you start grinding or blasting it out. I'm a big fan of POR-15 for projects like this -- the best product I've ever used for this purpose.
Don
AA1PR
Disabled Explorer
POR 15 or rust shield the areas after you sand in down to as close as bare metal as possible.
the stuff in spray cans are useless
if the area(s) with holes need filling and are in an area that is/are prone to moisture use MarGlass (fiberglass reinforced~very fine strands) instead of bondo or the other types of plastic filler.
I would also try to get some of the POR15 to the inside of the door along that seam if possible as there is most likely rust there that you can not see, may require removing the door though
Daryl
I can't agree more. POR 15 is the first thing I thought of when I saw the pics. I'd go for some light brass brushing to get the flaky rust and the paint that is covering the 75% of the rust you can't see yet, clean it well, and POR 15 it. If necessary based on how far you have to go to get it all, top coat it with an appropriate color.....chances are out of a can will work well enough since it's a place you aren't going to see much of and the POR-15 will provide all the protection needed even if the paint doesn't go on thick enough.
nakota
Thanks guys! You've given me some excellent advice, I'll update this thread a little later and let you know how it turned out.
FellowTraveler
Rust converter then chassis encapsulate r finished by POR-15 in those hard to reach nooks and crannies outside must be sealed too or the rust will keep advancing. I use Eastwood always cause their stuff rocks and you need to decide if you need a salt neutralizer too applied before the above products.
Revco
"Restore" Rust Converter is what I use. You gotta wash out the trapped debris that is creating the moisture inside the door & pinch welds of the lower door edge. Water to wash it out. Then regular ol Vinegar to clean it, then flush with water again and let it drip dry and try to dry it with compressed air. Then you have to clean/sand the areas you can reach, coat the visible and insides with Restore or Ospho, or any other rust converter. After a couple of days to fully cure, you can brush over it with POR-15, or KBS Coatings, or even paint. Just make sure that you fully encapsulate the corrosion affected areas to prevent any moisture from getting back into the areas.
Nothing will fully stop the rust except a total removal of it, which in most cases like yours just isn't an option. It's like cancer.
turbolab
i got this happening on my truck aswell so i'm building a sand blaster, i already tried a wire wheel and that just slowed it
Buliwyf
Viking with a Hammer
Monstaliner has a cheaper version of POR15 that works well. Still, don't forget the metal ready.
Don't plug those holes. Those let your doors breath and dry out.
Is this a Dodge thread? This feels like a Dodge thread.
