East to West, MLO's Utah Adventure - 2012
Main Line Overland
Supporting Sponsor
We got up early and hit the trail again. Knowing that we were headed to a big wash-out about 30 miles up the trail past Potato Bottom. We knew that many groups before us were forced to turn back and retreat the 70+ miles of trail they had already covered, but we wanted to determine for ourselves if it was really impassable.
We came upon Potato Bottom where we found two long stretches of deep mud ruts they we were able to get through. We then proceeded up the steep cut in cliff face and down Hardscrabble.
We descended and past the next campsite. Right about when we came to the Upheaval Canyon trail, the bespoke wash-out presented itself. I looked as though a river had cut itself into the landscape overnight, wiping out a huge portion of the trail. Where the trail used to be was about a 8 foot wall of dirt and sand. There were some motorcycle tracks we traced that found their own path. We decided to take another route around the sand and potential problem areas. We drove directly up the wash, which was a little slick but had packed down after 24 hours of no rain. The wash meandered for about 200 yards, then we turn back onto the trail which was very messy, basically gunning it to get up a sloped slick section.
Where the road used to be:
We were elated we had made it through where others had failed, mostly because we didn't want to retrace our path out, and we now had plenty of gas to continue on without tapping into our auxiliary supply. A little further down the road we found our next campsite, Labyrinth where we will camp along the Colorado River tonight before completing the trail tomorrow.
Main Line Overland
Supporting Sponsor
We completed the White Rim Trail and headed back to the Visitor Center to check-in and let them know that we were OK, considering all of the storms that had rolled through and what not. When we talked to the Ranger she thought we had only driven out to Potato Bottom and turned back, as everyone else before and even some after us had. We corrected her and said that we were able to make it all the way through the trail, which blew here away considering the portions of the trail on the west side they knew had been washed away. The cars were completely covered in mud when we got off the trail, and when we came back out of the visitor center there was a bus load of turists off-loading and a crowd formed around both cars with the jaws gaping, it was priceless.
A few more shots:
Dualsport bikes that went out ahead of us but then turned back at the wash-out.
The hills have eyes :)
Potholes at White Crack, like the surface of the moon
Jumping the crack
Main Line Overland
Supporting Sponsor
Needles District
After the White Rim Trail we went back into Moab and refueled and resupplied for our next backcountry stint. I also hit the car wash to remove the mud that was becoming adobe brick on the underside and sides of the car. Solar panels on the roof don't work too well when they are covered in mud. We headed south of Moab to the Needles District of Canyonlands National Park. We stopped into the Visitor Center to pick up our backcountry permits. We spotted this parked outside.
Meet Needles Nelly, a long active Park Service vehicle that still hits the trails. What a classic!
Jim K in PA
Great pictures guys & gals. And much respect for doing what you are SUPPOSED to do when faced with a challenge like a trail washout. Find a way around! That is the ENTIRE REASON you build up a rig. I would have done the same as you - that is the challenge I relish.
Love the CJ still in active service! But only because it is in dryland. No rust!
Keep the updates coming.
Main Line Overland
Supporting Sponsor
Jim,
Thanks, we were happy to see the trail all the way through. We saw another local backcountry offroad guide outfit on the Elephant Trail in the Needles District and they had heard about the wash-out and gave us props for completing it. That made us feel pretty good, considering these guys run the trails around the area countless times a season.
Matt
Main Line Overland
Supporting Sponsor
Elephant Hill
We picked-up our backcountry permits at the Needles Visitor Center, and spoke to the Ranger before hitting the trails. A number of trails had been closed due to flooding. Luckily our planned trail, Elephant Hill was still open, so we headed for the trail-head. We aired down in the parking lot before hitting the trail because one of the most difficult portions of the trail is right at the start, with a steep climb and some dug-out portions of the trail to get through.
Here are some shots of us on Elephant Hill and the rest of the trail:
The backside of Elephant Hill
As if it wasn't challenging enough...
The Devils Pocket
Ace Brown
Retired Ol’ Fart
I probably would have gone around the washout too, but leaving the trail could subject you to some serious fines, particularly in a National Park. I did the White Rim in a supported MTB trip and recall our guide telling us they had to keep the truck very close to the road when stopping for lunch, etc. like 20' or something close to that. Designated campgrounds were the only exception. I hope this doesn't sound like a lecture but it could save someone from a big fine one fine day (pun intended).
Ace
Main Line Overland
Supporting Sponsor
Ace
Ace,
Good point, you should not stray off the designated marked trail. We had been in contact with one of the rangers leading up to this run and knew we were working within the boundaries he recommended and had allowed others to do prior. In truth we did no venture far from trail, or in this case, where the trail *used* to be :).
We were reassured by the rangers after that we were fine in doing what we had done as well. Others who had come that far and turned back had to be rescued with spare fuel from the rangers in some cases.
Main Line Overland
Supporting Sponsor
Elephant Hill con't
Here are some more Elephant Hill photos.
Devils Pocket
Devils Lane
We took Devils Lane down to Chesler Park and my wife Kristen and I hiked the Joint Trail. I highly recommend this short 3 miles round trip hike. Once we entered the tighter rock sections we found some amazing spots, including this cave where we found hundreds of rock stacks.
We created our own before we left to head back to the vehicles.
Main Line Overland
Supporting Sponsor
We headed back up Devils Lane and camped at Devils Kitchen.
Here are some shots of where we stayed:
We used our Goal Zero Light-a-Life camp lights powered by our Goal Zero Extreme 350 solar power pack which was charged daily by the roof mounted solar panels on our JK. This made for a great hang-out spot in an amazing and remote location.
Here is Peter making his way back down Elephant hill on our way out the next morning
Mad_Texan
Brings back great memories from April whenI was out there with my dad!
Starting to wonder if you guys are going to make it back for your open house...:smiley_drive:
