We want to prove out the concept, but it will be a series of tall polyurethane (progressive) bump stops that can be installed between the a-arm and frame, allowing a slow-speed extraction option for the vehicle. The goal is to ensure confidence while traveling, even if the air suspension fails that we can get back to the road and a town for proper repair.
We promise to detail the entire kit and process once proven out.
Sounds promising. Below are a couple pics of my LR3...rear swing arm was custom made by LR forum member and myself. For the LR3/4 platform, what are you looking to do with the rig to actually drive the need for 32.5s or 33.5s? If you're wanting to do some rock crawling or tackle the Rubicon, then it makes sense, if not I think you're wasting your time/money as 31.5s will get you thru just about anything you can throw at it besides rock crawling & the Rubicon.....the combination of 31.5s and the LR traction control system is quite eye opening in terms of what it can tackle. Also, be aware that just going from the stock tire size to 31.5s kills the corrected MPGs on the LR3 from 19-20ish to 14-15ish. So keep this in mind as 33.5s will drive that even lower.
