Here's a dumb question:
If I understand correctly (and maybe I don't?
) the ADD does the same thing that locking hubs used to do, that is, it disconnects the wheels from the drive mechanism in the axle so that when you are in 2wd and the front driveshaft is not turning, the front wheels can spin freely without having to also turn all the metal in the differential and axle shafts, right?
The idea being that with less metal turning there is less wear-and-tear on the front axle and better MPG from having less drag due to moving parts not moving.
But locking hubs can simply be left in the "locked" position, too (or they can be removed entirely - for example, until the M-1008/1009/1028 CUCV were introduced, the US Military
never used locking hubs on their 4x4s. On the early Jeeps, Dodge 1/2 and 3/4 tons and other military 4x4s, the front axle turns all the time, even in 2wd and the military just accepts the additional wear-and-tear or MPG loss.)
So my dumb question is this: If you're having trouble with the ADD, is there any reason you can't simply remove the mechanism entirely and just leave the front end "locked", even in 2wd? Aside from minimal wear and maybe a MPG or so, what would be the down side to this? Honestly, I have had 3 Toyotas with ADD since 2007 and I've never had a lick of trouble with any of them, but if I did, I'd be tempted to just pull the damn thing out altogether.
Along the same line, am I correct in assuming that the full-time 4x4s like the 80- and 100-series LCs, the V8 4runners and the manual-tranny FJ Cruisers don't have an ADD? Because with no 2wd capability, why would they need one?
So the thing about locking hubs is
