Equipt - National Luna 9-LED Light - Installed on a 2013 Jeep Rubicon
Barrows
Sleeping comfortable inside the Jeep with everything I brought minus the chair I left outside that night. It's all packed nicely in behind the Engel.
I am jealous of your setup here. My tj is fun but sometimes I wish it was a little longer.....
weaselox
How hard was it to snake the wires through the hardtop? Any suggestions on how you did this? I'm getting ready to run the same setup and I want it to mirror your install
Gear
Explorer, Overland Certified OC0020
I drilled a half inch hole at the bottom to accept the grommet. You might try using a smaller size drill bit at first and work up to the appropriate size. The hardtop is some sort of fiberglass/plastic and has a tendency to splinter/chip. If you have access to a step bit I would use this. Then I simple used a piece of 18 gauge wire to fish down from the top. Then pulled it thru using a small pair of needle nose pliers and a scratch awl. Then simple tape the real wires to the 18 gauge wire and carefully pull them thru. A little patience and you should have success.
Good Luck!
weaselox
After about an hour of trying to fish the wire down and find it through the hole, we did! I ended up stopping the install after getting the light wired up, weather stripping on. I just need to go in this week and connect the wires from the light to the jeep and go from there. I'll take some pix once I have it finished up.
Thanks for a great write up and inspiration. Very much appreciated.
Gear
Yikes :eek: Well at least you are coming down the home stretch. Looking forward to the photographs.
marshal
Burrito Enthusiast
what pad are you using to sleep with? also, what did you do to cover the 5" gap on the seat back when its folded down?
Gear
I am currently using a Nemo Cosmo Luxury Pillowtop 1P with a Strato Loft 25 sleep bag. Although I have used other 2.5" thick sleeping pads in the past. Just for information this Nemo pad is 25" wide. For the 5" gap I just stuff a jacket or a soft bag to take up the space. On this particular trip I actually put a semi full MSR Dromedary Bag in that location. Kind of like camping on a water bed - J/K. Here are some links -
http://www.nemoequipment.com/product/?p=Strato+Loft+25
Nemo Sleeping bag
http://www.cascadedesigns.com/msr/w...reatment-and-hydration/dromedary-bags/product
Cascade Designs - MSR Dromedary bag
Both products are Fantastic.
marshal
Burrito Enthusiast
sweet thanks. my current (and only) bag is a mountain hardware is 45 degree mummy(read 55 degree bull****)
looking at figuring out a way to bring all the stuff id want to bring for a couple day expedition, have a place to sleep on the inside for me and for a 90lb newfoundland/GSD mix lapdog.
