What did you do to your Expo Jeep today?
BADDANDY
Yes, I've read a few threads and by everyone's opinion, the double wall is the strongest place to mount them. I also will run an aluminum strip on each side to use instead of washers. If the thickness is good, I'll use T-nuts and paint the strips and nuts white so nothing will be barely seen on the inside.
I got the right rail installed last night. I used the aluminum strip with 6 t-nuts and painted it all white. I'll cut off the extra threads when I take the hardtop off in a few months. The strip is the same length as the rail. Both 6.5" from each end of the top. Rails are 36 3/4" long measured without end-caps and are 48 1/2" center of rails side to side. Rail cut at the front end, new hole drilled there, then 2 more equally spaced between existing holes. All holes in rail, strip, and top are diameter of t-nut shaft diameter.
I first drilled rear hole into the top from the inside, drilled hole in the strip, mounted rail, then drilled hole for the front hole thru the rail into the top and to mark strip.
Then I removed all and drilled the hole at the front of the strip.
I then remounted all with rails and strips, front and rear screws and nuts, then drilled 4 remaining holes thru rails, roof and marked strips.
I removed all to finish all holes and paint and reinstalled using silicone to fill holes before screw install.
The t-nuts fit the screws that come with the fiberglass install hardware. I hammered the t-nut teeth flush before install, but they still have a little bite left to bite into the strip.
MattScott
Approved Vendor
I added a full set of MAXTRAX along with the rear tire carrier.
You can check it out here. [link]
VanIsle_Greg
Got my extended length Monroe 58643 coilover rear shocks installed yesterday. Added about 1.25" in the rear...
That looks good Camber. What lift are you running in there, the RC pucks? I have a set in a box in the garage to install still, and will be looking at shocks too. I tow with my WK, and have thought about those coilovers.
Yuman Desert Rat
I removed the Hannibal awning, attached the alu-boxes, rotopax and trasharoo. All I have to do is throw the RTT on top and pack the fridge for next weekend.
Victorian
Replaced the factory roof rails on our Liberty with a pair from Rocky Road Outfitters.
Now we have a solid foundation for our RTT :)
Breezy78
