Kimberley Inspired Camper Build
joey.hendrix
Frame and floor bottom painted
Last Saturday was warm enough to get the frame painted. Also got the floor panels cut, fitted, and bottom painted.
protohyp
I'm not sure how your planning on raising and lowering but there is another builder that did the same thing using actuators on four corners but he got low speed (maybe to accommodate for weight) and it took a while for it to raise 3 feet. I use Firgelli actuators as there fairly inexpensive and they have all the actuators you need if you go that route. I just built my actuator that pushes and pulls cables using a garage screw drive running off a 18V drill motor that is running off 12V and it's pushing 250-300 lbs depending on the pulley assist calculations. Anyway I'm subscribed as I can't wait to see what you come up with
joey.hendrix
Floor Installed.
Have the frame in the shop because it was too cold to work outside. Very cramped but I was able to get the Floor installed on the frame. Its held down with counter sunk carriage bolts and lock nuts.
joey.hendrix
Wall Panel Lamination
My plan is to build the walls from 1" styrofoam insulation sandwiched between 2 sheets of 1/8" plywood. I was planning on using West System epoxy to bond the styrofoam to the plywood. After a test to see how much epoxy it was going to take it became apparent that it was going to take a lot. That stuff is really expensive and time consuming to mix so I decided to find an alternative adhesive. I really wanted to use contact cement but it melts the styrofoam. Did some more research and found a water based contact cement made by Wilsonart.
Ready to roll on the adhesive.
This stuff works! Its the consistency of milk and almost no odor. Laminated 3 panels and cut them to size on the table saw.
dcollier32
How long does it take to cure? Also, where can I get some?
joey.hendrix
I got it at Wurth (formally Charlotte Hardwood Center) in Charlotte NC. Paid $55.00.
It was 75f, sunny with a breeze so it took about 10 minutes for it to be ready to bond. Just like any other contact cement, once you bring the pieces together the bond is instant.
joey.hendrix
Exciting afternoon
Got some more wall panels made up this morning. Had planned on mounting panels to the floor but instead spent half the day fighting a wild fire. This is a video still from my helmet cam.
joey.hendrix
Progress Report
Beautiful weather this weekend. Got a lot done.
Used West System epoxy to begin gluing the panels together. Will follow up by covering all seams with fiberglass tape and epoxy.
joey.hendrix
Update
Continued gluing wall panels to each other and the deck. I Move it into the shop and night. Tight fit.
Hugo checking out the progress.
Houie
