Mundo4x4Casa
West slope, N. Ser. Nev.
I've used a Premier Power Welder since 1996 and have maybe 100 hrs on it. It is very forgiving and makes you look like a better welder than you are. I bought it to self-weld the front axle SOA perches and shock mounts to the axle, and subsequently a few more jeep SOA's. It was a sight with the front of this CJ8:
up on jack stands with no front axle under there. Kind of a toothless wonder. I used 7018, high nickel content rod as I was partially welding on the nodular cast iron pig. I also carry around 6013, 6011(for out of position) and my fav, the 7018. No problems so far. I have welded new driveshafts together in the field, reattached broken shock mounts, broken NV4500 shifter shaft back together (at 2:45A.M.), patched broken frames in the field, reattached pulled off spring mounts, patched up metal fences, worked on trailer hitches, cracked cross members, and bent a tie rod back to straight and welded a piece of angle iron to it, which stayed that way for years. Ah, there is no fix like a trail fix. You know, the minute someone knows you have a welder in the group, you are a target for those 'didn't fix it at home' guys.
The thing i like about it is it will weld 1/2 inch plate, has an aircraft engine speed throttle, alternator puts out 180 amps. There are things i don't like, like the plastic cover does not let you see the position of the switches. The regulator is the weak link in the system. I had the engine worked on and the guy inadvertently leaned on the switch, switching it to high weld and I drove it home and found I had fried the voltmeter and the regulator. The regulator is the thing that goes on this rig. I carry a spare, which i have replaced in the field.
Some folks have had very bad luck with these, and I do miss a guy that built the predecessor to this one (On Board welder?) named Robinson, who knew this portable welder biz better than any one, would always talk you thru any breakdown.
As far as using a stick welder in backpack form, I am skeptical. Don't you need a battery to absorb the shock loading of the current? If you need a battery, you better be thinking hand cart or small wagon.
jefe
jefe
