Atoyot1031
For sale is a 1997 Toyota Land Cruiser with a custom offroad popup camper. This is the ultimate setup for both on-road and backcountry travel. With this setup, you can go anywhere and you will be very comfortable once you get there. This setup also easily maintains the speed limit at high altitude on mountain roads/highways.
Land Cruiser specs:
• 4.5l engine mods
o Supercharged
o 2.6” SC pulley
o Custom top mounted air-to-air intercooler
o Subaru STI hood scoop custom painted to match
• Cooling mods
o Custom match painted hood louvers
o 14” pusher fan wired into medium pressure switch for automatic control
o Tuned blue hub fan clutch with 100k silicone oil
o Fan clutch blade from 3FE
o Lowering opening temp themostat
• Suspension mods
o ~5” custom lift
o OME shocks
o Adjustable front control arms
o Adjustable panhard
o HD tie rod
o Double cardan front driveshaft
• Armor
o ARB front bumper with Warn M12000 and AC dryer skidplate (in cab “stock” winch controls & master power switch under hood)
o Slee rock sliders
o Kaymar rear bumper with dual swingouts and integrated backup light floods
o Full length custom roof rack
o Transfer case skidplate
• Additional mods
o African Outback drawer system
o Long Ranger auxiliary fuel tank (total capacity ~70 gallons)
o Headrest DVD players with wireless headphones
o LX450 stereo w/ center console for CD changer
o Pioneer door speakers (x4)
o Powered subwoofer in rear PS quarter panel
o Uniden CB w/ quick connect 4’ antenna
o UltraGauge OBDII interface
o ARB compressor and air locking differentials (front & rear)
o 4.88 gears
o (2) IPF offroad lights
o Brand new 37” Trxus tires
o 33” studded snow tires
o Drilled and slotted rotors (front and rear)
o EMS Powered Exhaust System
o Many extras as well
Custom Popup camper specs:
• Custom built HD frame (5/16”x2”x3” main supports)
• Custom built HD camper box (3/4” plywood with aluminum siding)
• Custom soft suspension system for real offroad travel including Rancho shocks
• 7000lb trailer axle w/ 33” tires
• HD steel rear bumper with integrated 2” receiver hitch
• Lock N Roll multi-axis hitch
• Custom paint to match Land Cruiser
• Diamond Plate Aluminum road rash guards front & rear
• Sleeps 5 on custom memory foam mattresses
• 35 gallon fresh water tank with 12VDC on demand water pump
• Electronic ignition furnace with upgraded ignition board to avoid low battery problems
• All interior & exterior lights are LEDs
• Custom wet storage on tongue of trailer
• Custom stabilizer jacks for tall trailer
• Custom cabinetry throughout
• Instant fully adjustable propane water heater that services interior sink and exterior shower with quick disconnects on all water & gas lines for easy setup and storage (includes instant setup shower shelter)
• 12VDC outlet inside
• Roof vent with 12VDC fan
• (2) auxiliary oscillating fans for hot weather
• Master switches for water & furnace
• Upgraded charger/inverter
• Two burner stove in galley
• Custom ladder for access
• 1000w generator
• Many extras
The Land Cruiser has 220k miles on the vehicle. The engine was rebuilt at 90k miles.
