underdrive
jackwagon
Well with my idea you can still use your current SS lines, the only difference between what I suggested and what you came up with (which, again, is exactly the factory '70s setup so tested and reliable) is my way you need an extra SS line and an extra hard line. The advantage though is that you don't have a long flexible line dangling there waiting to be snagged on something - which, admittedly, may not be a major concern at all.I am not sure exactly how I will do it, but I never though of doing what you are suggesting. That is a pretty clever idea you have there. I will probably do some variation of a new hard line from the MC to to a single SS line over the center of the axle, then down to a tee on the axle itself. With this method I can still make use of the SS lines I had made fort he calipers and only need two simple hard lines and one simple flexible. I will need a new hard line for the rear since they are teed off the drives side front from the factory.
For the rear you shouldn't need to do anything at all. The factory setup has the fronts and rears completely separate, the front line comes down from the master to the driver-side hose and splits off towards the passenger side there, the rear line comes down from the master and right into the RABS unit, and from there it shoots all the way back to above the rear axle. If your rear is currently t-eed off the front driver side then it's been monkeyed with, and you need to address that ASAP as should you lose front brakes it will take the rears out as well - with the factory split setup you can lose one axle and still have the other one in the game, pedal will sink nearly to the floor of course but you will still be building pressure in the good brakes.
