bugwhacker
I changed my mind from my old build as I found a much better unit for me to convert. It meets my design criteria of being no wider than a normal van and if I take the wheels off it can be stuffed in a cargo container for shipping. I needed more headroom and I found a nice Bus to convert instead of the Falcon/B190 I had. The Falcon body only left me with about 4 foot that I could actually stand up in and it was narrow (4" at the top).
I would love a 4x4 Sprinter but this is what I can afford and it has a motor that will run on the diesel they have in other countries with no trouble from a modern engine. This body has just as much room as an EB Sprinter and I can still do the 1975-1978 round headlight conversion which I like the looks of.
Inside it is a big empty box which is perfect for me to customize. I found it in a junk yard and bought it for $1100 including a rear axle complete of my choice so I can upgrade to disc brakes. I don't know who they thought was going to buy it for the $2000 they had marked on the window. It runs okay and supposedly has a reman 7.3 IDI in it with an e40d transmission. I still have my 7.3 van with the pathfinder 4x4 conversion on it for my parts van so I should have most of what I need to fix it.
My van is a 1991 so no Ujoint style conversion for me but I can either do a body swap or move all the 4x4 parts over from my parts van. The parts van is an e250 and the BornFree is an e350 so I am leaning towards the 4x4 swap. The 4x4 is a Pathfinder conversion - so coils on radius arms. Is there a spring over conversion for these or is it all some type of link setup? I would really like to go to a D60 front axle but mine only has a D44 under it. Is there a coil over axle that will fit reasonably that is a D60 or am I stuck with D44 or going to a leaf spring front?
