virginia_jeeper
Craft Beer Explorer
Pretty nifty. I love 2 door cherokee's just not pre 97's...
"Moving forward, does anyone have any recommendations for mods in the $50 to $100 dollar range?"
How about some body armor?
http://www.jcroffroad.com/product/X...F1t51OKPn7UfSuFV889wpKBcYBiYfXBy88hoCpbXw_wcB
Thanks anyway, I have been using my phone for GPS, just not sure if the signal will reach into the forest, guess there's only one way to find out!
Really nice rig!
If you haven't figured it out yet, your GPS signal should work anywhere on the planet that you've got a decent view of the sky. It will eat up your phone's battery though.
BackCountry Navigator is an awesome app that lets you preload satellite and topography while you've got a data signal, save it, and bring it up when you're out in the woods. (Yes, that sounds like a commercial. No, I'm not affiliated! Just really happy with mine...)
As for your $50-100 ideas, you could try a set of sway bar disconnects. If you haven't tried it yet, you'll be amazed at the difference wheeling. (Disclaimer: I always had a helluva time getting them reconnected. Now I run no sway bar at all, and don't miss it a bit. You'll have to try it n see if you like it...)
Or, a good charger to keep up with that GPS. The cheap ones may not cut it.
Since im going to need to be able to drive highway, removing the sway-bar is not an option.
I have looked into a set of sway-bar disconnects, but JKS is the only company which makes disconnects for any lift under 3".
If you decide to get a long aal do not get the RE 2.5 leaf. It put mine at over 3" and didn't settle, rode like crap and caused driveline problems. I took it out and installed a BDS 2" long aal and it rides like stock, also true to its lift height. The RE leaf doesn't taper out at the ends like the leafs should. Just my $.02,
