Bushwacker Inc.
Supporting Sponsor
Looking good! The Coopers look great, by the way.
Andy
Andy
Andy
Good call on the drip rail mounted rack, the factory rails tend to pop off when they have the weight of a tire on the rack. Funny but not if it's yours LOL. I am doing the same cooling system overhaul for the same reason, did you replace the thermostat? If so did you go back with a 195 or drop down? One thing I have learned being on my 4th XJ is that if that dinky fan shroud has the bottom broken out of it you will have temp problems, as a noet rockauto has it for 11.99. Cheep insurance. The front fender cut looks good, if you decide to cut the rear you may want to look up some you tube vids on using rear TJ flares on all 4 corners of the XJ. If you take your time with them they look good. Good looking start you have going bud.:victory:
Have you noticed a drop in temps with the louvers?
looks good, I have those same louvers in the same location
Talking louvers, every XJ should have them LOL. Here are mine on my current build, made them out of an old house AC unit. Can't beat free LOL
