Tundra with 4 Low not working, need help
The time mine wouldn't engage in 4W LO I was at Windrock as well......mine ended up being a cracked low range gear in the t-case.......then there was the broken front pinion shaft, pretzeled rear drive shaft, broken mirror, crushed fender.....I'm pretty sure Windrock hates Tundras :p
I think in your situation, the trail you were on was probably a bit more on the double black diamond rating to have that much damage.
Bamagirl, I had the same issue with 4Lo. Multiple times, I disassembled the actuator and greased up the contact points and internal moving parts. The actuators are definitely not the best working system. Which is why I swapped it out for a manual transfer case. No more push button for me.
Bamagirl, I had the same issue with 4Lo. Multiple times, I disassembled the actuator and greased up the contact points and internal moving parts. The actuators are definitely the best working system. Which is why I swapped it out for a manual transfer case. No more push button for me.
I know all too well how rough Windrock can be on things... I have ridden atvs and sxs's there for the past 10 years and it is rough on machines.... I only did trail 2 in the Tundra and I was uptight and holding my breath the whole time.... I don't think I am cut out for the big leagues with the Tundra.
I sold my Rzr last week and now I am out of the sxs off-road hobby, I didn't feel near as bad about taking it on the trails as I did my truck.
I am still able to engage the 4wd but only used the 4 high this past weekend while I was roaming East TN and NC. Granted there was really no need for it but I was trying to keep the spinning to a minimum on Parsons Branch Road. I have a little squeak or whiz sound coming from it and am beginning to wonder if it could possibly be the U joints in the drive shaft. I have had the trunk since it had 36,000 miles on it and after this weekend I think I am up to 223,000 miles and I have never replaced any U joints. It doesn't make a jerking sound like my dad's Chevy in the years he has had it, about 25 years, and the U joints have been replaced on it and it used to be my daily driver when I was a teenager and I had the drive shaft fall out coming home from work late one night so I have had experience with U joint issues in Chevys but not Toyotas.
I am very shocked at how well it has held up over all this time and the miles. I realize there is probably way more maintenance things that need to be done but I am just not able to do myself. So before yall tell me what all I have failed to do, just know I do what I know to take care of it and what I learn from research.
Dyogim, I don't mean it ugly but I am glad I'm not the only one that has had an issue with the 4 lo and feel better knowing I'm not the only one fearing the dreaded push button 4wd... I refused to have push button shifting on my atvs because of fear of gears getting stuck. If it wasn't manual shift I didn't want it.
In my previous message I meant to say "not" in the following sentence: The actuators are definitely not the best working system.
In any case, if it comes down to having to replace the actuator or xfer case, be sure to look for parts from a taco, 4-runner, FJ within the same years. A lot of the parts are interchangeable and will save you money. Compared to dealer prices.
That's great information!!! Thank you!!
Jlbeats
