Luxury Chase Truck Build [2007 F250-Carli Coilover]
CAPT.HODGES
Busted *** yesterday on the side and front rails. Had a big problem with galling until I googled it and learned. Anti seize for the win.
Front strip was a *****. Had to super glue the washers and nylocks on to get them started and then slip it the wrench.
Holding **** outta the way already...
Hoping to get the floor rails done by the end of the week as soon as I can get a second set of hands.
Love it so far. Best decision I've made yet.
CAPT.HODGES
Shredded some cheddar today
Boom. Now for the fun part. Re-strapping as much as I want and building bolt-on racks! All in time.
Big thanks to Jesse for the help and space
TrailWhale
Awesome build man!
But I'm partial to white crew cab short beds, my current truck is a white 2012 F250 XLT, 6" lift and 37s. My old white 05 Lariat was on a 8.5" lift with 40" MTRs. Had a ARB bumper, snorkel, etc.
I have a pelican cooler and love it, it sits in the open bed of my truck (with a cable lock of course) and holds 2 bags of ice plus drinks for 6 days. It is all melted by then, but even the water is still cold.
smlobx
Wanderer
Great write up and build. I have an '06 Larriet and have done many of the mods you did.
You might want to look at your alternator. Unfortunately the one Ford put in the Super Duties is the same one they use in the Fusion!! Many guys are going with larger units to keep the batteries fully charged and the FICM happy. I ended up going to www.ficmrepair.com and bought one of their upgraded alternators and upgraded wiring loom. $ well spent.
Also, most guys are going to an ELC coolant (like Cat ELC coolant) to keep the internals from getting gummed up.
One question how much of a lift did the Carli suspension give you when it settled out?
Thanks.
CAPT.HODGES
Awesome build man!
Thanks dude. Sounds like a sweet rig you've got there. I've debated a winch bumper of some time, but really want to keep it clean looking. Probably going to have a skid plate built soon. And yeah the Pelican cooler is essential for our long, isolated desert trips!
Thanks.
My alternator has actually already gone out once. I replaced it with one from Autozone I think which was higher capacity. I had to get it done quick. When it goes out I'll look into an even higher amp alternator from somewhere. I have also swapped coolants, and actually rebuilt the whole top end haha. Much more to come on that. Still copying over! Everything you've seen so far was months ago. Not really sure where the Carli kit settled, as I always have a load in the bed, and I swapped wheels and tires when I put it on, so there's no real way to measure. It probably pretty close to 4.5". Thanks for the interest!
CAPT.HODGES
Thanks to Tommy today for schooling me on shock rebuilds. Rear shaft is replaced and ready to be bent again!
Also threw up some quick fists for extinguishers and the jack handle, some temporary. Hoping to get a couple more tweaks done for this weekend. Thanks again Tommy.
CAPT.HODGES
Reposting from the Thanksgiving Cuddeback Lake Trip
Sooo I guess I should put in my .02 now
The girl and I rolled out early Friday morning from HB with a decent load
Set up King Ranch Pit 1
Camp
Husky Memorial
Retired Air Force Gunnery Range-now UAV testing area
Lakebed
My family made it out, but I forgot to get a pic of their rental motor home
Taking dirt home when Mikey DNF'd
CAPT.HODGES
Home from work in one week and then the fun begins. I've got almost everything ordered and sitting at the house. Gonna be the most intense project I've ever done but if I can pull this **** off, I'll be confident in most things engine-related from then on. (for those unfamiliar with the 6.0, most shops lift the whole cab off to do this job)
There are a lot of ways to "fix" a 6.0, some cheaper, some different. I've elected to go all out (once again) and have it be a bulletproofed workhorse for many years to come.
Parts:
Major
-BPD Oil cooler, heavy duty, cold weather kit (min oil temp thermostat), BPD remote oil filter
-BPD EGR cooler (will still function when I want it, or turned off with the tuner)
-Bypass oil filter setup
-BPD billet water pump (tough choice based on price but the bottom line is-it's not uncommon for the plastic impeller to crack at the hub and freewheel-can't afford that in the middle of nowhere, so I'm swapping it while it's wide open)
-Zerex ELC coolant (swapping out ****ty Ford Gold)
-Rotella T6 synthetic oil
-ARP head studs
-OEM Head gaskets (2)
Minor (most of these are update parts from International which eliminate a lot of common failures)
-Rocker carrier gaskets (2)
-Exhaust manifold gaskets (2)
-Fuel injector o-ring kits (8)
-Thermostat
-Oil rail dummy plugs (2)
-6.4 banjo bolts (2)
-6.4 banjo bolt washers (4)
-HPOP/STC fitting update
-IPR screen update
-Turbo rebuild kit
-Water separator drain update
-Degas bottle replacement (mine is baked and caked with Ford Gold)
-Cold side intercooler metal pipe update
-CAC boots for pipes (4)
-SS clamps for boots
-Fan clutch wire harness guard (easily severed by the fan if the clip breaks)
-CCV mod (temporarily vented to atmosphere, waiting on a deal for a racor CCV filter so I can maintain vacuum on the case-helps seal the rings apparently-and clear smog check, not drip oil, or pis people off at stoplights with blow-by gases)
-Header and exhaust wrap as far as two rolls will go (Donahoe racing SD started a fire when a tranny line rupture leaked onto the exhaust, I figure it can't hurt, plus the engine bay is always hot AF...going full chase here)
-Replace cracked heater box with one I snagged from the junkyard
-SCT Tuner, not looking to hit the drags ever but once it's studded, I can safely pull a little more pep out of this whale
This is what it's gonna look like...gotta get worse before it gets better:
attachment.php
attachment.php
Ok, question for people with more experience regarding airflow, coolers, and power steering/brakes than me...
Because I'm converting the water/oil cooler to an air/oil cooler, that cooler has to go up front between the ac condenser and radiator. That's where the current power steering cooler is located. Anyone who installs this kit is required to relocate it and usually purchases the cooler from earlier models (which is mounted down low as seen in the following picture-it's only a two pass cooler).
It seems like I keep burning up the fluid in the dirt because it gets worked so hard. I had the though of upgrading to a little tranny cooler to help it out. There are three nice options below. The smaller the better so it's easy to mount, but the fan is attractive because if when I go through with the skid plate, it doesn't look like it will get any flow at all.
Question: will one of the coolers without a fan still work well enough with the skid? Or should I just rig up the fan version and be safe?
It would pretty much go right on top of that ac condenser above where the small oem one is
attachment.php
Mishimoto with fan
attachment.php
Flex-a-lite with a nice guard
attachment.php
Small Mishimoto but double the tubes of the OEM
attachment.php
This is the kind of restriction I would be looking at (yes I could cut holes but if a winch is ever a plan then it wouldn't much matter)
attachment.php
Thanks for any help. Happy New Year
CAPT.HODGES
Day 1:
Got started on the tear down today. A little bit of a slow start as I was getting set up and figuring out how to manage tools and parts. Got the front clip and 3/5 coolers off. Tomorrow should be big progress. Thanks to Jessea for the helipad!
CAPT.HODGES
Day 2:
Had trouble with the trans cooler line for which you need a special disconnect tool, and no it's not the same as a fuel/ac line. I should be able to pick it up from o'reily in the morning.
Got the FICM off and disconnected a lot of the harness, labeling both sides of every plug along the way. Spent way too much time getting the heater box out. It looks like the Carli shock tower limits the clearance on that, so I ended up cutting some of it out since it was broken anyway. I have a new one from the junkyard. Probably going to remove the tower to install it. Hopefully I can get more off the top tomorrow!
Also got my portable shop all set up. Rolls right in my buddy's garage. Easy setup, easy clean up, saves my back lifting the top chest in and out of the bed every day, and I can leave all the chargers plugged in.
TrailWhale
Hows this for clean?
It's a WARN hidden winch mount.Spaces the bumper out To make room for the winch.
CAPT.HODGES
Nice rig! Looks great on your truck. I've seen those kits around but am still undecided as to whether I'm going to run a winch or not. I also need some kind of protection up front for the trail mobbing I do. Got to get through this wedding first haha. Thanks for the input
clearwater
