Post pictures of your Land Rover.
Jwestpro
Here is few of my rigs
Why so many pictures of a lifted Ford?
Are you quite certain that Land Rover is a "Defender" .... ? ;)
Jwestpro
Mortimer after new tires (265/65-18 BFG AT KO2s) - Btw, ran part of trip at 15psi which we determined was too low. Will try 18-20 next time.
18-20 is not going to be much different than the ridiculous 15 psi on that tire size.
18" tires on wheels like these on an lr3 should not really even be lower 25 psi. 28-30 psi is plenty low depending on vehicle weight. There is not enough sidewall to make sense of such a low psi on it's very small tire volume. If you had an appropriate sized tire like a 12"x35 or 37" , then you could try the super low psi.
IvanKV
I am having a mechanic do it all so there is not much to write up. I will do an overview of the truck when it it ready.
200Tdi installed update:
spikemd
Glutton for punishment. 3rd british engineered vehicle in the stable that I purchased today. Ground clearance may be an issue...
rcharrette
Kennebec Pass, Durango, CO
Took a trip up Kennebec to drop off my wife and Son for a MTB ride. Great morning up there so I cruised around a bit and took some pic's.
greggarnett
