What did you do to your Mitsubishi today?
kevinreeves116
Got my 32x11.5r15 Mastercrafts and 15x8s on the other day
bikerjosh
Started replacing my driver side CV joint/axle. Went well until I needed three hands to get the steering knuckle/hub/brake disk back bolted up. Waiting for my buddy to come over. :sombrero:
Use a jack under the a arm to line it all up!
Edited. Autocorrect screwed up
Porvalsh
Did some cleaning. Applied RainX to the windshield, polished the hood a bit to work on some of the scratches. I also got some leather stuff onto the seats.
Hood looks good in the shade, lol.
Porvalsh
Did headlights...I didn't really need them done but thought I'd give it a try and see if it helped. Not sure it did...
Before After Pics
Looks good until you turn the lights on
Also replaced radiator cap. The system was sucking my hoses in rather than breathing.
cacattack
Full timing belt service on my 2005 Gen 3
Replacing timing belt, water pump, idle bearing, tensioner bearing, tensioner, thermostat and oil pressure sensor on my 2005 Gen 3 with 97k miles.
JBThompson
Finished replacing the brake system's hardlines, and replaced the rear pads and rotors. Started doing the fronts but I'm going to need tools I don't have here so those are waiting until later this week when I can get her up on my lift at work.
taunger
