OBS F250 slow adventure build
I need to get up there one of these days. Its starting to get chilly for swimming now.....
Yeah we thought about swimming to the island, but no one was brave enough to attempt it!
Here is the video from the trip up and down
Thanks man, I am still using the super stiff factory 3/4 ton rear springs. However I am thinking about swapping them to 1/2 tons for now to soften the rear up and get more flex from the back. Eventually I will three link it and ditch the leafs all together for the best ride/flex combo.
I made a trip to pull-a-part and gabbed a few things for the truck. First was a tail light to fix my trail damage.
I also got several different temp sensors for the overhead console. The one that came with it was reading way low. After trying all four sensors I was a little discouraged as they all read the same 19* when it was about 60*. However, the next morning it was reading correctly! It must have needed to reset or something.
I also got the mic mounted for my CB. Nothing special but it is nice to have it in the same spot all the time.
I've pounded out a similar dent by drilling a hole on the inside of the bed and beating on a piece of 3/4" bar stock, rounded at the end, with a hammer. Turned out pretty not-bad!
Seeing as how I have hit that spot several times and the bed is pretty bad in other places I won't worry about fixing it. That is part of the reason I have not replaced the drivers fender or door. As soon as I do it will get crunched on the trail!
Dents are stories. If you love your truck, and the dents don't cause operational issues, they can be kinda cool. I got a couple on my trucks. Every time someone points out one of mine I can re-live the event again. Unless it is a dent because I did something stupid. Those ain't cool.
Superduty B codes are almost a direct bolt in and a definite ride improvement. The front hanger and rear shackle get drilled 1/16" larger. The front bolt moves to the rear, and the springs come with a new front bolt.
Aren't those front springs in which case they won't work on this truck.
There are Superduty A, B and C codes for the rear. They are a near bolt on just as I described. I can provide ratings if it helps. I have the B code on my '96 F250 4x4.
For the front there is a range from S through X codes. But as these are Superduty length a RSK bracket or similar is required. This truck already has a much better front end suspension so I am sharing this as further confirmation that my suggestion is applicable to this truck.
Either way, I enjoy this thread!
I plan on building a three link for the rear and I don't need the 3/4 ton springs for most of what I use the truck for so if I slap on some different leafs it wil be from an OBS f150, cheap and bolt in. Thanks for the info on the SD springs leojr!
Dynamo TCX
