custom camper examples
BigDan
IdaSHO ,
you are inspiring me !
I bought a 93 Ram W250 with a Cummins ......
I want to get rid of the original box and do a flat bed ......then either slide a regular camper and close the sides or do a slide in camper like yours !
Dan ,
back woods
My F700
attachment.php
BigDan
I have a concern .....
If the coach section is integral part of the vehicle , aint there a risk of breakage or warpage due to frame torsion in trails .......
Maybe this is why some people go for a slide in box camper only when offroading .....
because let`s face it in rough trails the frame tends to twist ,and it is noticeable that a regular pick up box will twist at a different rate then the cab ....
your opinions ?
Dan
IdaSHO
IDACAMPER
Apples to oranges in many ways.
That rig is probably built using a cab/chassis base that utilizes a very stiff straight frame.
For the most part, chassis flex is pretty minimal. The suspension must do all the work.
The entire coach does look to be fiberglass as well, so some flexing would be perfectly fine.
The fiberglass if properly built will allow for some flex without damage.
With all that said however, flex is inevitable, especially with such a long vehicle.
So building a unit like that is quite a task if you want it to survive off road.
Bassman770
Camper isn’t custom, but the truck is!
boxcar1
boxcar1
My 1990 Ford F-250 With scratch built coach . Steel chassis / composite panels. Super light ridged and as a whole economical.
This was a long ghost town trip around central and eastern Oregon. Mostly improved and gravel roads Ergo, the high mile Pizza cutters. The truck normally sports 33's. On these tires and with this load we managed 16.5 miles to the gallon over a 1,500 mile trip with a well tuned and prepped small block gas burner. Manual trans and T case. Fun trip.
AZXPLOR
