Not at all. If you are severely overloaded I dont have to tell you about your truck and camper.
Youll find out for yourself :sombrero:
And never did I say such a location would not work.
Just stating a simple fact with regards to how AC units work.
That, and one basic law of physics, heat rises.
Placing them on the floor forces them to condition (remove humidity and cool) air that has already been conditioned.
So instead of a roof or high wall mounted location, you fail to condition that air that needs it, the warm.
To fix that problem you have to run the unit longer than you would have to otherwise, super cooling the floor and waiting until the entire camper is cooled, or use more energy by running good sized fans to circulate the air.
Im sure you thinks it "works", and it may very well, but the fact remains that it is the worst location to place an AC unit.
Mt simple advice is to find a better location, and do not limit your thought process to low lying under cab space that happens to have a compartment door.
