mbroughton02
The rest of the screens are finished! I have probably 30 hours in them. It sucked. But it's done!
The past few days I've been working on the canvas. I bleached the whole inside. I have stains on the roll up "shades" that appear to have come from the exterior brown vinyl rubbing against the interior cream colored vinyl while in transit:
At first I thought it was mouse urine (this camper has definitely had mice) but then I realized that the brown stains were found exclusively on the roll up shades and nowhere else. Since the roll up shades are the only thing inside that could possibly contact the exterior vinyl, I think my theory is sound. When I thought I was dealing with urine I tried vinegar, soft scrub w/ bleach, comet w/ bleach, tilex w/ bleach, mr. clean magic eraser, ammonia, and even some carb cleaner (closest thing I had to acetone), and nothing was working. Once I determined it was dye from the exterior side of the vinyl I figured it got on there by rubbing, it must come off by rubbing. And bleach should be a solvent for the dye...so I tried the soft scrub w/ bleach again.
This time I applied it and scrubbed vigorously with a scrub brush for several minutes in each spot. The stains started to fade. Then I called it a night but just left some soft scrub on a spot before I left, as an experiment. When I came in the next morning I scrubbed away the dried soft scrub, and the stain was noticeably faded even more, but with much less elbow grease. So I went with that method for the rest of the stains. They are faded, but they definitely are not gone. Good enough for now...I can't stand to breathe in any more bleach. I forgot to take an "after" pic but if someone is interested I can take one later.
Then I used the tilex to clean the entire exterior side of the canvas. Left side is before, right is after:
Next up were the holes. I had a big mouse hole almost 3" across in the front left bottom corner and several smaller holes. Previous owner had patched with duct tape but I wanted to do better. I took @MDM54 's advice and looked on sailrite.com for some vinyl I could use to patch holes. After browsing their site I realized that you can buy 4"x4" samples of their vinyls for $1.00 each. I needed to order HH-66 vinyl cement anyway, and their price on that was good too. So I ordered 3 samples of the closest I could find to the interior cream color Mobern Seabrook Gel White and 3 samples of the brown, which I went with the Naugahyde Universal Doe.
Here's what the samples look like:
They are much thicker than I needed, but I'm okay with it. The color isn't an exact match either but I didn't expect it to be. For $24 including cement and shipping I'm pretty happy with my patches; they are much stronger and look a lot better than duct tape:
That's it for now.
That's it for now.
