Gen 2.5 Mitsubishi Montero 2000 - Over-landing Family Truck - long term enhancement
nwoods
Ray, thanks for the response on the Trasharoo. I don't think mine came with that supplemental tensioner strap, and my tires are a bit bigger than yours and I just couldn't get the darn thing on.
raysobi
How thick is that new front skid plate compared to the factory steel one it replaced, would it stand up to a hard hit from a rock?
Its a solid skit plate and a lot beefier than the stock for sure. Definitely more durable.
Sent from my HTC One_M8 using Tapatalk
PajEvo
JDM Journeys
Just wanted to say great thread. Love how you started off with basic, and have moved up as your comfort level increases. Keep it up!
Phil
Monterado
Great looking truck. I am jealous of your low miles. I had two green ones similar to yours.
How are those 33's working? Any rub? I am looking into some new rubber, sliders and a skid.
I too would like to know where you got that skid.
-Cory
raysobi
Practicing Mig Welding
raysobi
I finally opened my plasma cutter box after a year of not using it......unfortunately my 220v outlet for my welding machine is not compatible with the plasma cutter plug....nooooooo
Are there is any kind of adapter that I can get so it converts to the correct design for my plasma cutter?
I even took a day off so I can work on my rock sliders....epic FAIL WHALE.
Sent from my SAMSUNG-SM-G935A using Tapatalk
shmabs
not that you always should, but its generally easy enough to swap out the wall mounted plug. most of the 220v plugs have different styles for different amp ratings. Or using some parts sourced from a home improvement store, you can make a simple extension cord with the correct plug on it.
Disclaimer: I'm not an expert household electrical circuits.
Mike
raysobi
Mike
Thanks Mike, since my welding machine is already using a plug that matching the current wall outlet , I went ahead and grabbed another plug at home depot.
It works!
JPT4648
