Heating a pop-up truck camper?
craig333
Has anyone tried moving the thermostat from the stock location? Wouldn't be hard to do, just two wires to relocate.
cchoc
Wilderness Photographer
I replaced my stock FWC thermostat (White Rodgers) with a Honeywell digital and it works much better. The thermistor is much more sensitive so it reaches equilibrium quicker and maintains a more constant temperature. It does cycle on and off more than the old one but I think the total on time is about the same.
ebgb68
Hello the wife and I plan to pickup our first camper tomorrow. Are you guys running CO2 detectors in your campers ? Running a Buddy heater seems it would be a good idea I know they aren't that tight but it worries me some.
Thanks Ed
topher800
Thanks Ed
My camper came with CO2 up high and LP gas down low....though the lower one detects dog breath too.
cdthiker
Meandering Idaho
Mr Buddy for the win.
Get the extension hose and plumb it to your main tank. Dead low will use very little fuel.
A co2 detector is 25 bucks at wally world or lowes and depending on the size of the mr buddy and the hose you might get out for less then two hundred bucks.
nobueno
Thanks Ed
i wouldn't sleep w/out one. we have a co/smoke combo up high and an lp down low.
elmo_4_vt
I was reading the thread over on WTW and had that thermostat saved in Amazon to be one of the first things I installed after getting my camper, however to my surprise, they changed the stock unit in the camper to that very model. They must have been reading the forums, or maybe just know their stuff too. It worked great for us BTW. Very little delay in the readings, and was able to go all the way down to 40 for sleeping/being away in cold temps.
Don
1stDeuce
We've used my hallmark down to -14F once with small electric heaters to supplement and it was fine. With the furnace only, we've camped many many times in the single digits and teens.
The soft walls and window covers in my unit are thinly insulated, and it does OK as far as I'm concerned. We typically sleep in sleeping bags, and set the thermostat to 50-55F at night. (If you want it to be 70F all night, a motel room is really the only option.)
I would estimate that at 0F, the heater runs about 40% of the time, once things equalize. That's a lot, but it also pulls air through the cupboards, and keeps my water and lines from freezing. Using electric or non-air circulating heaters means not having any water in the camper, as it'll surely freeze.
With a forced air furnace vented to the outside, I don't worry about CO, but if I was to use a Mr Buddy, or similar catalytic, I'd probably add a detector. I don't think my camper has a propane detector either, now that I think about it, but that stuff stinks really bad to me, so it's not likely I wouldn't notice a leak big enough to be a concern...
Have fun winter camping!!
deadbird
I vote Mr. Buddy.
It is silent, won't wake you up when the fan turns on over and over.
Uses no battery power.
Takes up less physical space.
It heats up my Grandby really well.
fireball
I am considering a Hawk shell and using our Mr. Buddy, the same one we currently use in our tent. Happy to hear that others are using it successfully, it seems a lot cheaper than the offerings from FWC or others.
dtimms
Are people running the buddy heaters all night with a fresh air source? I imagine this is completely safe.
To go with this question, Anyone have issues at altitude with the Mr. Buddy? In the winter we camp at 9000+ near ski areas. My furnace in my 2001 phoenix will drain the battery in a night. I have a rigid generator as a backup but it sucks to climb out in the cold and fire that thing up. Solar would be nice to recharge the battery but we are usually chasing storms so there can be a foot or more of snow on the roof so that doesn't work.
Jonny Adventures
