Loving your build, I just got a 1993 Squire 3000, heading out for our maiden overnight today.
Keep up the good work, giving me lots of ideas!
Our maiden voyage went great! No issues at all. I felt a little bit of sway at times, but have since installed airbags and we went out again this weekend and everything was tight. Things I dealt with in getting it ready were pretty basic, the lance plug had been removed and replaced with a 7 way so I put a gooseneck plug in the bed, added airbags to the truck and put a couple sheets of 2" foam underneath to clear the cab of the truck.
Just starting to figure out how long the battery, propane and holding tanks will take us. So far we have filled the grey water over two weekends of use and the fresh water is down to about 1/3. No shortage of power yet (we are in Alaska, so not a ton of lights being used this time of year) and the propane seems totally unaffected, though I'm beginning to grow suspicious of the fill gauge.
The best "fixes" I've done so far have been adding a piece of 1x to the inside of the lid/floor to the small platform the table plugs into so when the table is off the floor doesn't slide off, and adding some waxed cedar in the channel below the pass through window so it is held in better. It's the little things!
Other than that, I need to get some stairs, it's just high enough to be a hassle, even with a large action packer as a step.
I have factory optioned overload leaf springs on the truck, with bilstein 5100's valved for the F350. I love them. I am afraid if i add air bags it will push my load just to where the overloads are barely touching their perch pads and I think that might mess with the ride or create some unwanted noise. So I will let the current setup ride for awhile to see how i like it. I have only had the camper on once for the ride home. I have had the camper off refurbishing it ever since.
Consider making the overload engage sooner by lowering the bump stop. Pretty simple to do, and fixes a lot of issues.
I was in a similar situation with mine years ago. With the camper loaded it BARELY contacted the overloads, but looked like it was dragging its butt on the blacktop.
With the bump-stops lowered, I have zero need for bags, the truck does not squat so it handles better, and overall ride is improved, loaded and unloaded.
Not my rig or picture... but this is how it is done...
I still have the viewing screen. I was thinking about flipping it vertically so I can see the full level, instead of just the top when it is full???I would have loved to just adjust the overloads springs on my truck, but they were removed long ago by the previous owner and replaced with something else that also disappeared before I got the truck.
The overload bump drop looks simple and effective. Having no overloads, I went with bags. A Big Wig Swaybar would also help, no doubt. If nothing else, it has been a great way to level the camper once camping.
Looks like I should start my own thread so we can compare notes! Keep up the good work. And in case you don't know the small framed out area above the breaker/fuse panel has an expanded metal screen allowing disability to the fresh water tank on mine. I have found it nice for a quick check of the fresh water tank level.
