I am anxious to run gas. I have a larger machine in the works. I will run a bottle off of that from the start.Looks good so far. Add a bottle to that little welder and you're life will be so much easier.
What wall thickness is the 2.5" tube on the frame?
Thanks!Looking good!
Added the interior pieces and finished welding the main frame.
Thanks! The cart was just a necessity. Something I probably should've done a long time ago. Buying one would be too easy. What I really wanted out of it was practice welding the thin wall tube and working with the 16ga sheet. That will be the basis of the boxes I build, so this cart project helped to dial me in with the welder.Your trailer is coming out great, I like the welding cart too!
Thanks! I am having fun with it.Love the build so far! Question, what size is your final frame dimensions?
Looking good so far. Have any plans on what water tank you will be using?
