Another Gen1 Tundra Thread
AaronK
I'll have to check again to be sure. I think it was 22.75"
Sent from my OnePlus One using Tapatalk.
AaronK
Well I tried to install my differential drop Saturday night but the bolts were corroded and my Ryobi cordless impact wrench's 200 lb-ft weren't enough to break them. Rolled my rig into work today and used an air impact and made short work of the job. Dropped my CV angles back down nicely.
AaronK
Ok here's some measurements for reference for anyone that may be searching the interwebz.
OME 885 springs
Uncompressed: 15.75"
Mounted on 90004 Nitrocharger struts: 12.5"
Compression at ride height: 11.5"
Stock ride height measured from hub center to fender: 19.25"
Final ride height, including ARB Sahara bar: 22.75"
toyotech
Wow that lifted it a lot. Hope they settle. I think that's to much
AaronK
Agreed. Though my CVs are what I was most concerned about and the diff drop and extra boot clamps seem to have alleviated any problem.
I'll keep an eye on spring style as I put miles on them.
theBullfrog125
When I installed my Old Man Emu Torsion bars it took over a week for them to break in, I had to keep adjusting them back to the height I wanted. I guess what I am saying is that it could take awhile for your coil springs to break in depending on how far you drive. I'd take it down a super bumpy wash board road to see if you can expedite the process.
AaronK
They'll be seeing about 100 miles of forest service road this Saturday. I'll take another measurement then
AaronK
So, fellow Tundra drivers. Let's talk about sway bars. Anyone remove or disco theirs? I'm considering giving it a shot due to the reduced body roll I've experienced since installing the new springs.
I'm thinking a disco makes more sense but I suppose I could just unbolt it and see what happens.
theBullfrog125
I'd take it off. The increased body roll is worth the increased ease of articulation IMO. I didn't experience enough body roll to care when I took mine off. My T100 is the same width as your Tundra and it feels plenty stable, even with my topper and RTT on top!
This topic is hotly debated but most are able to deal with the body roll for more efficient articulation, not just off road but on road as well.
TwoTrack
Buy Once, Cry Once
I took mine off over a year ago. I notice a slight increase in body roll but nothing dangerous.
AaronK
I'll probably give it a go. Have a trip coming up this weekend though, I'm done goofing around with things until after that.
flipstick
