Thanks! It's been a fun project thus far! On the bedliner, I haven't had any chipping of the coating as I put on 3 coats and used an entire gallon of the material. Harbor Freight sells a gallon of it for $50. I masked off the areas, ran an orbital sander with 200 grit and then put it on with a roller. I had to coat the hood as the glare from the LEDs on the sand beige hood was too much. I have noticed some small bubbles in the spray on coating I put on the hood, maybe that's due to engine heat.
My Burb has no rear seats but a steel partition as this was a survey vehicle. The back platform is constructed of 2 4'x8' sheets of 3/4" plywood with 2x6 beams to form the structure. I'm just a shade under 6'6" and 240 pounds so having enough area to be comfortable is a big thing for me.
I'm trying to get things in motion here soon to sell some things off and roll that money into the Cadillac build. I've got all the cam, valve train and what not done. I'm going to take it to a machine shop and have the block inspected, new bearings installed, new rings, pistons, and a full balancing. I want this engine to run as smooth as a turbine for a very long time.
Woof, really loving how the burb came together just re read the thread and gotta say very impressed. I was wondering about the bedliner and whether by now, if any of it has chipped off. Did you rough up the paint below?
Also what is the height of your platform, id always dismissed the idea too because at 6' plus sleeping in the back is always a tight fit, however now that ill have an extra 10 inches above my head I may go in on a short platform like you've done.
Great work and keep us posted!
