Lifetime trailer @ costco
RubiconGeoff
That's great! I've considered adding a receiver hitch to my trailer but it hasn't been a mod that's up at the top of my list yet. I like how you set up the fenders to mount. I'm looking forward to some finished glamor shots.
Deav
SO shakedown went well... Learned a few things quickly that were easy fixes.
#1 when you look at the pic when we started out i had 4 bikes off the back...bad idea...a few miles down the road of the tail wagging the dog, and I moved two to the front of the trailer and we were rolling steady.
#2 not enough gap for fenders to tires, will be moving those up as high as I can; will have to modify mounting system slightly, but the system was solid.
#3 forgot to share that i used some of those fancy led bolt lights to make sure I was legal with the plates.
Not pictured, but easy to imagine, the rear stab jack was welded to a piece of hitch tubing so i could swap it in place at campsite and still have some stability.
tacuba
does anyone know if this Lifetime tent trailer at Sam's Club is the same as the costco one?
I couldn't post a link, but here are the specs from the sams club site:
Description
Whether you enjoy a rugged outdoor adventure, or just need a little extra help hauling materials from your yard, the Lifetime Deluxe Tent Trailer is designed to outfit your lifestyle. Converting from utility trailer to tent in just minutes, the Lifetime Tent Trailer not only carries your gear for the great outdoors—it also provides a large, comfortable living space. From hauling ATVs and motorcycles, to canoes and kayaks, packing up your equipment and enjoying a weekend get-away has never been this easy!
Specifications
Trailer Specifications:
Trailer dimensions and weight allow for comfortable towing by compact sized SUVs
Trailer has a 2,000 lb. GVWR
Trailer bed is perfect for an ATV or other gear
Heavy-duty steel frame has a durable, rust-resistant powder-coated finish
Trailer bed features solid wood flooring
Ships as a kit with assembly required
External Trailer Dimensions: 126.5” L x 79” W (10.5’ x 6.6' )
Internal Trailer Dimensions: 85" L x 60 1/2” W (7.08' x 5.04')
Internal Trailer Dimensions w/ Gates Down: 113" L x 60 1/2” W (9.42' x 5.04')
Payload Capacity: 1300 lbs.
Side Gate Dimensions: 40.5" depth from trailer floor
Coupler Ball Size: 2” ball
Electrical: Four-way flat plug
Trailer Material: Powder-coated steel frame and solid wood flooring
Trailer Lights: Weather protected wiring to avoid damage
Gross Axle Weight Rating (GAWR): 2,000 lb. idler axle
Gross Vehicle Weight Rating (GVWR): 2,000 lb.
Total Weight: 700 lbs.
Utility Cargo Space: 123 cubic ft.
Tent Specifications
Spacious 7 ft. ceiling and 84 square-foot interior provides plenty of living space
Eight large windows and screen vents provide great ventilation
Weather-resistant bag protects the tent during transportation and storage
Tent Material : 150 denier polyester tent with 3000 mm PU coating for weather resistance
Tent Dimensions: 7' L x 12' W x 7' H
Tent Weight - 25 lbs.
Tent Frame: Aluminum poles
Wall Pockets: Integrated wall pockets for small storage items
Tent Bed Size: 2 twin XL beds - mattresses not included (sleeps up to 6 people including floor space)
Bed extensions available for queen sized
Tent Interior Height: 7 ft.
Interior Space: 84 square ft.
jeep_n_co
It's been many years since I've posted, heck it's been eight years since THIS thread has seen any activity, but I figured I would do an update on my OG Lifetime Tent Trailer. We still use it every summer and we still love it for what it is. I have modified it to fit matching 38" tires from my rig, which had some minor cascading issues, notably how it raised the tailgate so high that we now carry a platform to get up into the trailer. The platform supports are about at the end of adjustability but still work just fine, although I do carry extra blocks to put under them when the ground underneath is not level. We have had a couple of areas where the factory powder coating has flaked off of the top platform in large chunks, but that is an easy fix with some prep and a rattle can. We still have never put an ATV on top, we just never got around to getting one, but I have used the "utility trailer" config MANY times to haul stuff. When I finished my basement a few years ago, I put all the drywall in the back, and a several loads of 2x4s. It served well as my "pickup bed" before I had a pickup!
Underside still looks pretty good, no real issues with wood rotting. Although I think I will do some deck staining on all the wood this year.
At the end of every season, we take the bag off the trailer, take the tent out of it's bag and do a general clean/inspect. Takes an afternoon but it's good winter prep.
I found a great Waxed Canvas tarp at Tractor Supply and I use that to cover the trailer when it's stored outside at my neighbor's property.
I am starting to see signs of the main center support bowing. Today, my neighbor and are are going to fashion up a cripple out of 2" boxed 1/4" thick steel to go under that center bolt, which should prevent any issues with it breaking. I'll post up some pics once that's done.
Overall, this has been a GREAT purchase for us! But, we are considering stepping up to something different going forward, like a teardrop or something equivalent.
jeep_n_co
We ended up replacing the tow bar completely with a 3" x 3" 1/4 wall 9' section (instead of 7', so I have an extra 2'). Wow, rock solid now! I'm planning to mount the spare tire in the extra 2', plus possibly a couple of Jerry cans.
