Sawtooth XL Build
Door Jambs
Today was the day to finish off and mount the door jambs. I had the rough cut jambs glued up (except for the piece upon which the bulb seal is mounted) , and now they needed to be trimmed and mounted on the side walls. I had cut them oversize a little bit, and I also had the templates I had made for the two pieces which together formed the outline for the jamb.
My initial thought was I would use two sided tape to fix the template to a piece of plywood, and use the flush-trim router bit with the bearing on the bottom. Then I could fix the rough cut pieces onto the template and trim the outer side (the plan was to screw and glue the jamb to the side wall after the outer profile was trimmed, and then use the flush-trim router bit to match the inner surface exactly with the door opening in the side wall). So I started by putting the tape on the reverse side of the two template pieces.
I used double sided carpet tape for this application. It stuck the template to the plywood very well. Then I put some double sided 3M mounting tape on the template and placed the door jambs on that. I also tacked the two jambs together so I could do them both at the same time, a total thickness of 1 inch for the jambs, and 1/4 inch for the template.
When I adjusted the router bit for length, I discovered that the bearing plus its retaining collar and set screw were greater than 1/4 inch. Uh oh. Not enough clearance. So that plan was scrapped. I started taking the template off the plywood, and problems ensued because the tape did not want to release. Using brawn instead of brains (I have very little of either), I managed to get the constituent parts -- apart. Not without damage, though.
This is the reason I should have waited for the proper Baltic Birch plywood. Birch plywood is not the same as Baltic Birch. I have a whole rant about this that I am saving up about what not to do when building an offroad trailer with plywood.
So I get the two tacked together jambs with the template on it ready and clamping it to my "work surface," I clamp it and trim the outer profile using a bit with the bearing on the top. In a risque sense, you have to be willing to do it from the top and the bottom. (Emoji goes here).
I wound up with this. The jamb is glued and screwed to the inner wall.
The outer profile was trimmed as above, and after I screwed the jamb to the wall, I took the router with the flush-trim bit (bottom bearing) to trim the inner profile flush with the door opening.
Next, I had to cut and mount the lip on which the bulb seal goes. This was going to be easy. The outer edge of the lip had to be flush wth the outer profile of the jamb, and the plans call for this to be made of 1/4 inch plywood. So I tacked a piece of the material on the jamb which was slightly larger than the dimensions of the jamb. Out came the router with the flush-trim bit (bottom bearing), and I cut the piece to the exact size right on the door. Voila.
Then all I had to do was use a base plate on the router with an edge guide attached to get the 2 1/4 inch width on the lip. The first try resulted in an error.
I said words like dang and stuff. I figured out that if I cut 1/2 inch holes with the outer circumference 2 1/4 inches from the outer jamb edge to use as starter holes (and stopping holes) I could control the cuts better. This is what that looks like.
So it all worked out in the end.
Final Result of R=Today's Efforts
Both sidewalls have their door jambs on, and the first coat of finish has been applied to the inner walls and the inner face of the jambs. You will no doubt notice that the grain on the inner wall is horizontal, and the grain on the inner face of the jambs is vertical. Uh oh. Mea culpa.
I decided to call it a day after that and come back to my brother's place to clean house for the parties this weekend, and to sharpen up some chisels and a block plane I have borrowed. I can do this because I bought a piece of glass to glue my sandpaper to. $7.99 for an 8x10 pane of glass. Did you know you can't buy glass at Home Depot? Windows, yes, glass, no. Hometown hardware stores still rock.
I hope everyone enjoys our Nation's Birthday this weekend. What is it, 240 years? That's worth an apple pie or two!
But home depot gives treats to my dog, local guys say no dogs... all are trade offs.
Great build!
Thanks for the comment, and I really like your build too! I wish I had skills like yours. And the knowledge you have on running gear is beyond impressive.
As for the dog treats at Home Depot, I was wondering why there are always dogs there. Saw the beginnings of a great dogfight in the hand tool aisle last weekend . . . And Big Mike? Big Mike could not quite make it outdoors, and the person on the other end of his leash had to do the "Wet cleanup, Aisle 3" thing.
It is always a trade-off, isn't it? I looked all over in Big Box stores for single edge razor blades for a mini-project I was working on, and finally found them in the Plain Hardware Store. Same thing for single jig-saw blades.
Man, you guys with your mad wood skills both amaze and agitate me...because the only thing I've managed to do with wood with any degree of skill is turn it into a pile of charcoal. Well done on this build.
I wish I had the skills to which you refer. I've been away from woodworking for years, and I am relearning lessons from decades ago. You should see my scrap pile.
The best I can do with wood is create firewood. It's really ironic since my dad, my grandfather, my uncle all are/were amazing at woodworking. To say it skipped a generation would imply some aptitude - that would be a lie. I do build a nice inferno, though.
Buick doesn't do dog fights
it's really funny seeing aggressive dogs come to him. They get closer and their eyes get bigger, then they submit. I can just hear them "I was running up to chase that bad dog away, and he just kept getting bigger, and bigger..."lol
I was at the bb store to find FRP... I went home empty handed. McClendon will be my next shot on Sunday...
My mother had a Shi Tzu that would have been all up in Buick's grill. Had the worst case of Little Dog syndrome I've ever seen. The bigger the dog the bigger piece he wanted. I'm surprised that little fool never got himself eaten. We used to have a body shop and the shop dog was a beast of a Dobi named Igor. Big honkin Doberman. He wandered over into my mothers yard and she didn't know it. Let little Buffy out for his biz and that mini dog came out like a rocket running on meth. Igor looked at that little fireball headed his way and must of figured since he was so little but so aggressive he knew some sort of secret Dog ****, cause he turned his big hairy butt around and beat feet as fast as he could back to the body shop.
Little Buff trotted his tiny *** back to the house like he was King Turd. Funny.
Sorry for the side-track. :)
heh - I didn't say he didn't end fights.... what are those dust-mop dogs? they look like all you need to do is put a handle on them and they'd be a perfect dust mop (lord knows they're terrible dogs)... anyway, on a camp trip one ran up and tried to bite Buick on the foot. Buick opened his mouth, enclosing the dog, then pinned it on the ground... the message was quite clear lol.... dust mop went away with nary a woof (I think it was worried that if it said anything Buick would finish the job). I've no doubt that Buick would take care of himself if needed - but outside of that, it's never been needed.... size really does matter ;)
Why I Should Never Complain
I realized a few weeks ago that I sounded whiney early in this thread because I couldn't source parts, couldn't find this or that, too far to drive, etc. I apologize for doing so. It is really churlish, in my view, to complain about not finding something while in the continental USA (Land of the Big PX).
Now this guy? This guy only states the problems he encounters, his unhappiness with the problem, and how he goes about solving the problem.
http://www.expeditionportal.com/forum/threads/73982-Volvo-C304-(4x4)-Restore-and-fitout
I want to be more like him. Particularly when he wrote in his last post about using "the angry hammer."
Today my work plan is to put Monstaliner on the exposed parts of the frame, the tongue box, the fenders, and anything else I can think of that will benefit from a dash or two of black bed liner. Once that has cured sufficiently, I should be ready to start assembly of the body of this little beast.
Mr you sound just fine to me. If you want a taste of world class whiney like a spoiled teenage prom princess level whiney-ness, you should head over to my thread. I'm surprised anyone hung around to read it.
Watching the original build, and now this one, makes it realllly difficult to not add one of these to an already overly long list of projects "in process".
MonstaLiner is a Monster
One quart of MonstaLiner applied at 70 -74 degrees, is a monster to work with. Plus, it did not go as far as I planned. But I'm ahead of myself.
I got to the work site at about 8:00 to get started. The floor was ready to go with a canopy over it, and I spent about an hour getting some MEK to wipe down the trailer frame and fenders, moving the fenders and tongue box outside and setting up.
It was a nice day, cloudy and overcast to start. By noon, it was clear and warm. At a mile from Hood Canal, it was also humid. I spent the next three hours with my handy respirator on (something you really want to use while working with this and similar products) applying the first coat of black. By my calculations, there should have been enough for two coats of black, but I must have neglected to carry the three or something, because at noon, I had one coat on the items, and no more black. Whoops!
Fortunately, I had another quart of a dark gray called Pyroclastic. It is almost a battleship gray, and since that is all I had, I put it on after lunch. It came out looking pretty good.
I am particularly fond of the appearance of the tongue box. However, I noticed for the first time that it has a drain hole in each rear corner. I'm thinking maybe I should apply some JB Weld there and make the tongue box a little more water tight. Comments?
While at Home Depot, I also picked up some 3/4 inch Non-metallic Liquidtight conduit and connectors. I plan to use that to get the wiring loom from the tongue box to the rear of the trailer and up to the fuse box.
Work plan for tomorrow is, weather permitting, to start assembly. Forecast looks good for tomorrow, so we shall see.
Instead of sealing them with JB, weld a nut to the bottom under the hole, so you can thread a bolt into it and have a drain in case you do get water in there. Other alternative might be to use something like this: http://www.grateseal.com.au/ though I've seen them in motive power applications, so you may find something more suitable. They do seal against slight submersion.
rocksandtrails
