Most popular stove's used in Overlanding
joelbert
MSR
For those of you that love MSRs (and similar) for various reasons (reliability, portability, fuel, size), but don't really enjoy the noise, I stumbled on this product which I didn't even know existed.
aftermarket burner called quietstove: http://www.quietstove.com/quietstove/index.html
It's available for other stove as well. I ordered one for my MSR and will see how it goes.
Scoutn79
I await your review. I have seen the reviews online and it seems it affects the heat output and very slightly lowers the jet sound from the burner. Listening to the burner on videos it is barely noticeable...maybe in person it is much quieter. I love my Dragonfly (and it's predecessor the Firefly) except for the noise.
Darrell
precision powder
Backwoods Explorer
I have seen questionable reviews on that. I mean the noise really isnt horrible. Yeah it sounds like a jet engine, buts its not on for all that long of a time. I figure MSR knows what they are doing, they are arguably the best backpacking stoves on the planet, if they didnt put it on the stove there is a reason. Just my personal opinion though.
Darrell
I have read the same. The Dragonfly is the best stove I have used. I mean you basically never need to worry about fuel, unless you drive an all electric car or a hydrogen cell vehicle (neither reliable for what we do or a good choice) you will have at least a tank full of fuel to run it.
perterra
They work fine, there are two kinds, regulated and unregulated. Both work, unregulated puts out a lot more heat, but I have never had an issue with the regulated ones.
hyperboarder
I bought the Stansport a couple months back, works great. I carry a full tank on the Coleman grill, a 20oz MSR of white gas, and 4x 1lb propane cylinders for backup and/or the propane firepit. More than enough fuel for a weekend, nice having the option to just pop on a propane tank if I don't feel like starting up the white gas.
Scoutn79
I imagine it puts out wicked heat but using almost 400X the pressure the system was designed to handle seems inherently dangerous to me.
Portable/RV grill is designed to use propane regulated to 1/2" psi where the unregulated pressure from a bottle of propane could be as high as 200psi.
Darrell
perterra
Your converting a liquid fuel stove, propane operates no differently than liquid fuel once it leaves the bottle. The constriction of the small tube coming off the bottle and the valve keep the flow down but you can ice up a bottle with it.
If you are worried about it, then buy the regulated, they sell both kinds.
Scoutn79
The link "wagex" provided goes to a Stansport converter "regulator". I checked the Stansport website and don't find a converter that is designed to run at unregulated bottle pressure. Where do you find this? Do you have a link?
Darrell
madmax718
Has anyone ever used the Lindel to propane adapter? I am tempted to try the butane to lindel to propane. I do butane to lindel all the time, as when I travel, those cheap butane stove canisters are everywhere, including asia
perterra
Darrell
No part numbers, picked it up from academy sporting goods probably 15 years ago.
There was a discussion at one time on the Coleman collectors forum. The only real advantage I have found is in running 2 or 3 burners at the same time
perterra
I suspect that the opening in the burners is larger than the diameter of the tube feeding it so there is no pressure build up. But it may pull liquid out on a heavy burn of a 1 pound can. I run mine on a adapter for a 20 pound bottle. Theres not really an inherent danger with pressure on propane like there would be with acetylene.
AndrewP
Anyone using old timey Coleman stoves? Picked up a 413e and a 425e for a few bucks this week, seem to work fine.
More "Overland" "Expo certified" meals have been cooked on Coleman stoves than any other. They are perfect. Cheap, reliable, compact/easy to find fuel source, works in all environments, easy to field service, fuel efficient, last for decades, repair parts available at the local hardware. Seriously they are perfect for vehicle based travel. I'm surprised more people here don't snap up the 60's-70's models that remain perfect to this day, and are built with more a bit more pride than the current lot of dual fuel stoves (which are still good stoves), because all Coleman stoves can burn regular unleaded gas.
What's not to like? Other stoves have more sex appeal, but honestly don't work as well for vehicle based travel. When you travel in a 3 ton vehicle, you don't need ultra light weight, and even there a Coleman stoves contains it's fuel. So a propane stove plus it's fuel tank weighs at least as much as a Coleman stove with it's fuel tank.
Now if you're reluctant to learn how they work, and take the extra 30 seconds to pressurize the fuel tank beofre cooking, then propane is for you. Just don't cry when you melt the o rings out of your Partner stove's burner valves 100 miles from anywhere, or you run out of propane on the White rim. There is a craft to master when it comes to a Coleman stove, but once mastered, it sticks with you for life.
So yes, "old timey" Coleman stoves are still around. Still cooking dinner, and making breakfast. They probably are not expensive enough for the overland crowd, but from a practical perspective they are actually better than the alternatives.
Here's 6 burners of 1963 Coleman still cooking at an undisclosed location on Lake Powell.
141-jpg.1267887
Kevin108
The stove tech overlaps with the lantern tech as well. I'm a bit of a collector when it comes to the lanterns, and I love to use them, but it's hard to argue that LEDs aren't winning out at this point.
I don't know if it has been mentioned yet or not, but there's an adapter to let the "gasoline" stoves run off propane as well. I don't have one, but I like options!
AndrewP
I agree about LEDs for lighting, but you can't cook on LEDs.
As much as I like Coleman fuel lanterns, LEDs are great for evening camp lighting.
Stoves need real heat. Coleman fuel is great for that.
ilciclista
