The relay itself was not melting. The wire plug adapter hooked to the relay was slightly disfigured around one of the connections.
that indicates a connection problem, possibly but not necessarily undersized wire(the entire wire itself would get hot if it was really undersized), and not a melting relay... has a relay ever actually failed yet?
the specs for this compressor say that it already has a 30-amp inline fuse??? so i'm not sure about the benefit of putting a 40/50-amp fuse inline with a 30-amp fuse, the little fuse should blow first, perhaps someone thinks that the big fuse is somehow there to protect the relay, per the fuse location in this wiring diagram?? http://www.jeepforum.com/forum/f22/...k-dead-another-jeep-lives-1499894/index9.html
specs listing the 30-amp inline fuse: http://www.smittybilt.com/product/index/32.htm
