New additions to my GEN3!
cnutco
How did you remove the upper glove box, did you drill out the lock? this seems to be a problem on Gen IIIs.
Javy
I took it to the dealer, but yes, they drilled the lock out and replaced the entire "door".
marty1977
Must say nice vehicle you have there. I just got GENIII and have a quick question for you, How you like OME HD suspension. Im looking to upgrade and primary do exploring and soft off road not much big rocky trails and i cant decide between MD and HD set up but for sure i want more ground clearance. Hows your vehicle now driving it on normal roads? Im afraid if I go HD it might ride to harsh on normal roads.
cnutco
The HDs are not a soft ride, but they do seem to help the handling in turns on normal roads.
I would buy them again if I had the opportunity.
Djbenny
Javy
My glove wouldn't open once. It was working fine then it just seemed as if it was locked but no sign of a lock like the other. Looked on some forums and then drilled a hole same size as other and sure enough a keyhole was right underneath. Just drill the plastic covering it, so you can save the lock. Then just paint it black so it matches the other lock, i used black model paint.
Djbenny
Any update on your light bar set up? I just ordered on for my Monty.
cnutco
No Sir. I have been servicing the engine, a new y-pipe with new cats to finally get rid of my engine codes.
Djbenny
Oh yeah? What codes? Mine comes on every now and then for Catalytic efficiency below threshold I believe it is. I had my 02 sensors checked out and they are fine. So I will be dealing with that soon too.
cnutco
Can't remember the codes but it had to do with the O2 and catalytic converter.
I had replaced all the O2 sensors before. No
I had a complete tune up, rear cam seal, new vacuum lines, new catalytic converter y pipe, and one O2 sensor replaced.
No more SES light!!!
taunger
