AmboLander
patoz
@Pat. I am cautiously planning on leaving around the 15th, give a day or two... The sooner the better for your Christmas List!
Eric, I just put that on the top of my to-do list and will work on it first thing in the morning!
Thanks...
patoz
Thanks...
Eric, I sent you an email last night about this and I hope I got the address correct. If you didn't get it, let me know and I'll resend it.
AMBOT
Nice and quick work on your Ambo!
I use the lil buddy and it's gets the box real toasty in short order. I have a factory variable speed fan that keeps the air circulating.
Keep up the good progress, nice to work on it in the winter months in fla.
Baloo
"The Bear Necessities"
I used a buddy heater for two years and it was a great heater. It would cook you if left on high for too long. Just make sure you always put it on high first to heat it up before switching it to low.
FDM2012
Moving right along.......
These are the mounts after I tore them out of the Aerostar frame pieces that I cut out at LKQ.
Rust reformer and undercoating underneath, rattle can primer/paint on top.
1'' diamond matting. I drove it on the highway for a couple of hours, and it did cut the noise down a bit.
It should also offer a little bit more of a temperature barrier. I hope......
Eventually, I would like to put a swivel on the drivers seat.
The length measure about 6'6''. I am 6'0'', so it works out well.
FDM2012
Yes, it was important for make it very "utilitarian". I will use it for business every once in a
while to haul some stuff. Like today, as a matter of fact. :smiley_drive:
patoz
Eric, did you go on your trip to Blue Ridge this weekend? In addition to all the smoke, I think the weather was pretty bad also wasn't it?
V45W_Proto2.5
