AmboLander
I think you’ll need some bigger D ring shackles. ;)
Is your goal self recovery or recovering of others?
For self, your need a 16k+ winch. The general rule of thumb is 1.5x your rigs weight. A good 8k might do it if you’re double lining it, but then you’ll need to get even more complicated if that’s not enough. At least with a 16k, then double line gets you 32k. If 32k won’t do it… then you’re really in trouble.
Those shackles are a 12t, and a 13.5t.
Just trying to be somewhat prepared for whatever....
I am running a 12k winch. Hence, the many snatch blocks.
Death Wobble FIX:
The center mount bolt on the trac bar was worn pretty bad, and the frame holes that that it went through were waller'd out worse than a Rhode Island Red.
So, I drilled the holes out to 5/8'', bought a 5'' Grade 8 bolt and drilled it out for greasing the 3/4'' x 5/8'' x 1 3/4'' inner mount sleeve (not shown) that I BootyFabbed. Put in new bushings, and welded a couple of 5/8'' bore x 1/2'' shaft collars to the frame.
So, instead of just the 2 frame pieces only offering a total of 3/8" of pin support,, it now has 1 3/8".
The link you posted doesn't work any more. can you post what type of locks you bought? I have a McCoy Miller that I need to replace the locks on. And any tips or advise would be helpful too. Awesome build
Took a nice trip from Tampa to The Ozarks a couple of weeks ago for a family reunion. The rig did great! Sadly, I had stupid friggin Cancer a few years ago, and it cost me my spleen. So, my big dream of a long trip to The Yukon and Alaska in AmboLander will probably remain a dream. The risk of a simple damn tick bite could really mess me up, or worse. I reckon I will just relegate myself to campgrounds and just try to stay out of the woods and weeds. Another alternative would be to sell it and buy a boat. I do live in Florida, after all. I dunno..... Hope everyone is doing well and are putting your rigs to use. Cheers till next time!20250616_175337.jpg20250619_135727.jpg20250619_073241.jpg
nahuebsch
