Brakes upgrade Gen 2.5
evomaki
Hope those figure it out for you freewayross. I'm with bikerjosh, I too have a 2006 Tundra and those front brakes are the definition of mediocre. Different vehicle than a Montero, but I've never thought of the gen 2 Montero brakes as a weakness. They look pretty legit to me, and feel that way too. However, will be cool to see the brake upgrade I read about here.
Toasty
The ABS on all of my trucks turns off in 4WD (4HLc and 4LLc), i had one once that didn't inhibit ABS the first time out and it was scary offroad. Maybe check/clean the detents so the 4wd computer knows what's happening.
Swank Force One
Nope still riding with spongy brakes. Ordered all new flex lines from Rockauto, let's see if that fixes it.
Check/clean/replace your booster check valve as well if you haven't already.
I'm having an absolute hell of a time with the brakes on my Gen2.5. I apparently purchased it without working rear brakes. (seized and no fluid in rear lines.) Replaced those last may/2,000 miles ago.
Started dropping fluid last month, so i bought new front everything and a BMC to "carpet bomb" the whole thing and end up with new brakes all around effectively. During tear down, found that the passenger front caliper was leaking fluid out of one of the pistons. Buttoned up job, went on my way. Next morning, notice that the new passenger front caliper is leaking fluid out of one of the pistons. Had to order a new one and warranty on back end.
Installed that one on monday. Last night, wife texts me and says brake light is on for low fluid. Check this morning, sure enough, low on fluid. Passenger front caliper leaking out of where the hard line goes into it. Inspected flare and nut, it's clean and undamaged. Yet another faulty caliper.
Icing on the cake: Passenger rear caliper that i replaced 2,000 miles ago is leaking out the piston. Outside of warranty period due to time.
I've never outright had a caliper fail or leak on any vehicle in my life. And now this.
Swank Force One
Sounds like another case of abysmal-quality parts store "rebuilt" parts - avoidable if you get a rebuild kit and rebuild the calipers yourself.
https://www.parts.com/index.cfm?fus...one&Title=Mitsubishi-Montero-CALIPER-SEAL-KIT
Centric brand via Rockauto. I've used them on every vehicle i've ever had and never had an issue.
My oem stuff was not rebuildable due to extensive damage. I'm guessing that's what's happening here. People sending in ridiculously old and worn out cores.
Timboruski
