2011 4x4 F450 Custom Camper Build
MTNMOBL
Yes there is an 8" spacer on the rears, mostly so that the wheels look the same front to rear.
i wish i could say i did the offset calculation my self, but they are custom machined for the person i bought them and the tires from.
I would make sure that the tires you buy are rated for enough to make super singles
hope that helps
MTNMOBL
Well, it's here! Made it over two snowy passes! Be careful what you wish for! Now the real work begins! Thanks Total Composite!
Victorian
It's a pleasure working with you on the build! Can't wait to see the finished camper on the road :)
java
Very nice! Very similar to what I am working on.
Sent from my SM-G900T using Tapatalk
Jonstoy
Where did you happen to order those front fenders from? They seem that they are a pretty high quality fender even with the integrated flares. Looks amazing, great job.
MTNMOBL
We ordered them through the same person we got the wheels and adapter from, then had them custom painted to match the truck and "rhino lined" also. PM me if you are looking for a set.
MTNMOBL
I see some long days and late nights coming up.
Have you sourced extrusions for all the angles required for the assembly of the top panel to the side panels and the sides to the bottom?
We worked with user, Victorian of TotalComposite. All the extrusions came with the panels when we ordered them. We also ordered our windows, door and roof hatch through him. We are still doing some prep work on the body of the truck before we mount the camper body.
java
PM'ed you for some info on the wheels/tires. They look great.
How much lift did you end needing to run to fit them? I don't have a ton of above the wheel clearance on my box in the rear.
WonaWarrior
