Two days late.....Two dollars short
FDM2012
Rgr that.
I think it would be cool to have an excursion group here in the SE that meets up every few months at different spots.
Or maybe there already is one, and I'm just not "In the Know"??? lol
Oh nice. Maybe I will see you around when I move to Georgia.
Sent from my SM-G930T using Tapatalk
Bikersmurf
Extra large trans cooler, hitch, and brake controller are on the horizon.
6.0s have a much larger trans cooler. It's essentially a direct bolt in. You'll need to adapt your lines to fit its lines are about 1/8" larger. I've not done it, but it's mentioned in several threads.
lockedwheels
Thanks for the tip! I'll check it out
lockedwheels
Rgr that.
I'd be into something like that
4x4pair
Yea, the 6.0 cooler is much bigger than stock. That's the old cooler hanging on the bumper with the 6.0 behind it.
Sent from my SAMSUNG-SM-N910A using Tapatalk
lockedwheels
Tuner installed
Brake controller installed
Hitch and trailer light socket installed
Just ordered the new trans cooler. After that buying the trailer!
lockedwheels
Yeah there is a plug down by the fuse block for it. Then near the back bumper there is a plug that i cut off and used those wires as well as splicing into three others. I will have to look at my notes if you want to know what colors were which.
gtbensley
Only if its not a pain, I will be doing this shortly on mine and would love as much information as possible before I tackle it.
Smudge12
