1998 Mitsubishi Montero w/ Winter Package
TheMole
Price: SOLD
Needing a daily with better mpg so regrettably putting my gen 2.5 Montero up for sale. I bought it from the original owner back in September of 2014. The miles are high, but the car still runs great as it's been my daily for the last 2 and a half years. To my knowledge, everything works except for those listed below in the "Need Attention" section below. The biggest thing that doesn't work is the heater (AC works well). I bypassed the heater core when I noticed light fumes coming out from the vents while using the heater for the first time of the day. I did not want to chance any inhaling of toxic fumes or leaks in the interior so I bypassed it immediately. The heated seats were good enough to get me through the colder days.
Listing this just on ExPo for now as I would rather have it go to a member. I will be straightforward with any questions so feel free to ask.
Vehicle Info
Trim: Winter package (heated seats, diff lockers, etc)
Miles: 216,8xx (still driving it so miles may go up)
Registration: September 2017
Title: Clean in-hand
Smog: Passed smog on 4/22/17 (good for 90 days) and Star Test-Only back on July 2016
Upgrades
Pioneer DEH-X4600BT bluetooth/usb/aux stereo
Kenwood KFC-P709Ps component speakers for front doors
KYB Monomax shocks
265/70/15 Cooper Discoverer AT3 installed @ 199k miles
Maintenance
Timing belt service @ 182k miles - 1/2012
-Including water pump, tensioner, idler pulley, cam/crankshaft seals
Piston rings reseat @ 184k miles - 7/2012
Valve job @ 184k miles - 7/2012
Starter - 8/2014
Crank pulley bolt updated - 10/2014
Spark plugs (iridium)/ignition wires - 10/2014
Battery - early 2015
Front suspension - 2015/16
-Including idler arm, pitman arm, inner/outer tie rods, upper/lower balljoints
Rear brake pads - 9/2016
Front brake pads - 10/2016
Radiator - 1/2017
Drain and fill ATF w/ Eneos SP - 4/2017
More info here:
http://forum.expeditionportal.com/threads/132893-New-owner-of-a-98-Montero
Need Attention
Carpet/floormats could use a good cleaning
Driver's seat worn
Gas door doesn't pop all the way open when pulling button, but enough to open by hand
Heater not working (bypassed heater core)
Knee/kickpanel speakers not working
Roof clearcoat fading
Scratches on passenger side dash
Steering sometimes jerky over rough surfaces (control arm bushings?)
Extra Parts
8.5 qts of Eneos SP ATF
OEM radiator - needs rebuild/weld
CSF radiator - needs rebuild/weld
OEM stereo
Misc parts
Pics
speedtre
This is my EXACT Montero (other than color) that I sold last year. Similar mileage and maintenence history...mine sold for $2700 and I wish I never sold it. If you were closer I would buy this in a heartbeat (I just wrote off my Tundra). People simply have no idea how good a deal these are...I didn't know until after I sold mine. GLWS
TheMole
Thank you sir hope you find yourself a nice one again.
Mazdax605
Still available? Keyless entry remotes? 4wd work, and how about the indicator lights on the dash? Rear locker operational? Flexible at all on the price?
vertical.dan
