Redeth005
As promised here are the pix!
There she is in all her glory! I can't wait to try her out on a camping trip. This CVT roof top tent extremely easy to set up. It takes approximately 5 minutes to set up without the annex. And approximately 10 more minutes or so to do the annex (only because I'm not used to setting it up yet). The annex floor has enough space to fit at least a full size may be even a queen sized blow up bed.
This is the set up without the annex.
Don't worry about that telescoping ladder, i just hadnt figured out how to properly adjust it in these pix. It looks crooked in the pix. After i had figured it out i adjusted the unused steps and moved them all to the top.
It's huge. And as you can see on the inside picture you can see how much space is still inside. I am 5'8" 260lbs. And there's enough space to fit 3 of me up there. There will definitely be plenty of space for my girl and I and with her son Isaac.
I later learned while trying to set up the annex that getting it ready would be a hell of a lot easier if i had put the annex floor in front of the side of the trailer (where the tent opens up to). Another thing is setting up the annex would be 100% easier to remove the CVT tent cover completely because the annex slides into the same channel across the side of the fold that holds the cover on. and trying to get it inside is much harder to do once it is popped open and already set up. So next time i would definitely place the annex floor. Route the annex through the channel on the side of the tent. Then open up the tent and place the ladder on the center of the annex then pull up the annex and zip it up followed by the rest of the set up. Also considering it may be windy on some days the annex stakes would be handy to place right after it is zipped to the actual roof top tent.
Here you can see where i had already fixed the ladder issue. Now it looks good!
The trailer looks tiny with this tent/annex set up lol
Today was a pretty hot day. It reached almost 90 degrees. So when when my girl, Veronica, and i were setting up the tent we quickly learned that the aluminum metal floors and telescoping ladder get extremely hot; EVEN WITH THE TENT COVER! Opening up the tent at first was pretty hard because it burned to the first touch so i cant imagine how the heck we are gonna set up camp in desert areas lol At first with the crazy heat wave that we had i realized it was pretty hot inside that tent. BUT with all the windows open the inside of the tent we saw a huge temperature drop within the first minute. Especially since the tent sit's up high we got a really nice breeze. I had all the doors(minus screens) open and it wasn't too bad. I'm sure if we added a couple 12v fans in there it would be even better!
Also like i said earlier, I am 5'8" and i was able to stand under the annex just fine. The bottom floor barely touched my head so i approve. The height i built this thing at was perfect. Going with a 3" lift on the trailer was an excellent choice.
