Radiator splash guard
SkiFreak
Crazy Person
The temperature at my place has been consistently lower than normal for this time of the year, so working on my composite body build has yet again been put on hold. Sigh......
Not wishing to do nothing truck related during this period I have turned my attention to other tasks.
Anyone that knows these trucks would understand the potential issue of damage or blocking of the intercooler/radiator fins, as there is little to no protection. Also, if mud were to go between the intercooler and radiator, it would be difficult to remove.
Adding a splash guard under my intercooler and radiator has always been on my "to do list", but it was not high on the list so remained undone, until now.
My biggest concern about adding a big plate under the truck was the potential of reducing airflow to the radiator and intercooler, as the FG84 (FG140 equivalent) has a bit of a reputation for overheating. Personally, I have never experienced overheating issues with my truck, but I have heard from numerous others that have.
Anyway... not wishing to assume anything, I decided that a bit of before and after testing was required for this modification. To that end I bought a relatively cheap anemometer (a device that measures airflow) off eBay and built a small bracket to hold it in front of the intercooler. I then did some before testing, taking readings over a 3km distance @ 80 kph (six runs) to get my baseline measurement. I was happy to see that all runs yielded similar numbers.
My splash guard is a very simple, boring design, consisting of a 3mm thick aluminium sheet, with a lip bent on two sides for a bit more strength. Mounting the sheet under my truck was very simple too, as the coil suspension setup gives me some perfect attachment points. I used common bullbar LED light mounts and a few custom made spacers to attach the sheet to the truck.
After fitting the splash guard I took the truck for another run on the same stretch of road at the same speed. Much to my delight, the airflow numbers went up between 20% and 30% over five runs.
So... my conclusion is that the splash guard, as well as fulfilling it's intended purpose of protecting the intercooler and radiator, is acting as a very beneficial air scoop.
More pics of this modification on my website.
Aussie Iron
Pretty similar to what I have other than I used 3mm bisalloy plate and actually bent the front edge up a little. For our trip across the desert I added 6mm weave stainless mesh from the leading edge to the front chassis rail to stop spinifex and other objects from staking the radiator.
Dan.
SkiFreak
Crazy Person
Initially I was going to bend the front edge up too, but it sits pretty flat so I did not really see a need to do this.
I am also looking at adding a little wing on each side, that goes up close to the chassis rail. That will add another degree of splash protection on the sides. Will also add a bit of mesh at the front, but did not have any at hand when I did the install.
Mine was built purely as a splash guard, not a bash plate, hence the use of the ali. I figure that if I am hitting stuff that high on the underside of the truck I have a whole lot of other problems.
Does yours increase airflow to the radiator Dan?
Aussie Iron
That I can't really tell you other than it never made any difference to my running temperature. So I believe the air flow to the radiator is the same or enough. Running along tracks that are only two wheel tracks with grass in between you never know what is hidden in the grass and it only takes a little stick to spear the radiator.
You do know that with your coil suspension it is really made to use on very uneven tracks so you can use all that articulation that is available to you.
Dan.
blackduck
youll just about do anything to show off the underside of that truck Owen
but talk about cold
it got down to 14 degrees here last week
javajoe79
Fabricator
There goes my mind racing.... I am trying to resist giving up on my leaf suspension up front and this isn't helping......
Deleman
