DiploStrat
Free Advice is worth ...
what you pay for it. So here goes:
-- You won't ever fully charge anything through a cigarette battery. But it may not matter.
-- If you are only going three days, and you don't have solar, simply put the battery on a shore charger between trips. If three days only draws it down to 12v, you should be fine.
-- Get some decently sized wire and tie the positive to the positive terminal of your starter battery and the negative to a good ground to your frame.
-- Put fuses at both ends and use your choice of isolation system - manual switch or ignition switch, for example.
-- Put some form of properly sized quick disconnect at the auxiliary battery side, so that you can take it inside to connect to the shore charger.
This way you get as much charge as possible when you drive and, assuming a good shore charger, still assure that the battery achieves a full charge between trips and remains on a proper float.
