New from AEV: Ram ProCal 2013+ 1500/2500/3500
AEV
Supporting Sponsor - American Expedition Vehicles
AEV's ProCal Module for 2013+ Ram 1500/2500/3500 trucks is now available as a stand alone unit! This innovative, user-friendly recalibration tool that has a variety of unique features. One of the most popular features of the ProCal Module is its ability to correct the speedometer when larger tires (up to 48” tall) are installed. When the speedometer is left uncorrected, there is a major degradation in the performance of the stability control (ESP), transmission shifting, and engine performance – the ProCal Module will eliminate these issues by ensuring that the vehicle is properly calibrated.
Additionally, the ProCal Module is the only product of its kind that allows the user to recalibrate the TPMS system for larger diameter tires that have a lower inflation pressure than the stock tires – a common scenario that would otherwise lead to an annoying low tire pressure warning light. The ProCal will also recalibrate for axle gear ratio changes, allow users to turn the truck’s one-touch lane change feature on or off and determine whether or not the fog lights turn off or stay on with the high beams (for off-road use only).
The ProCal Module is equipped with a series of easy-to-use DIP switches. By reading the simple instructions included with the ProCal module, the user can quickly dial in a code for the desired recalibration. The entire process can be completed in mere minutes – once the switches are set, simply plug the ProCal Module into the vehicle's OBDII and wait for the horn to honk, confirming that the setting has taken effect.
Key Features:
• Compatible with 2013+ Ram 1500, 2500 and 3500 trucks
• Easy to use DIP switches
• Recalibrate speedometer for larger tires (up to 48" tall)
• Recalibrate TPMS*
• Axle gear ratio recalibration (3.21-4.88)
• Turn one-touch lane change on/off
• Turn fog lights with high beams on/off
• Optimizes ESP performance
• Will not interfere with most performance modules or tuners
https://secure.aev-conversions.com/shop/ram-procal-module
WonaWarrior
