Taxa Wooly Bear
We recently purchased at Wooly Bear trailer from Road Trip Camping in Virginia, we love it. Most importantly the wife loves it even more than I do!
Below is a link to our walk around video from Expo East 2017.
We will be modifying the trailer over the winter and will continue to post updates.
Cottontail
Easy Street on Mud Tires
Thank you for posting this.
The North American XJ Association (NAXJA) is about to take possession of this same unit, which we will be raffling off at our event in Moab in October 2018. Your build has been inspiring to our plans.
Awesome! We love ours, let us know if you have any questions. I wish I could be the lucky winner of the raffle.
bald.eagle
Looks like a killer trailer! Having the wife on board definitely makes things easier- I'm working on making our setup better tailored to my wife and kids' comfort, with the aim of getting them out in the woods more often!
Where in VA are you guys located? Would be cool to check out your setup sometime. We're down in VA Beach.
bueller44
Great video and walk around! Thanks for some of those ideas. I need to find some plastic bins for my kitchen and pantry area like you have.
Where do you put your propane tank? Mine is in the open storage area, but I really want to mount it somewhere on the trailer. Have you looked at any nose boxes?
Last question, my hitch is the normal one for a 2" ball. It's welded on. Did you have yours cut off and then the articulating one welded on?
Thanks
e60ral
2016 4Runner Trail w/KDSS
Does your awning frame just stay there, or is it collapsible?
Sent from my SM-G930V using Tapatalk
Awesome! We purchased this trailer because it had a kitchen that made my wife happy.
We're in Northern Virginia so a good 4hrs away from VB. Your welcome to check out the trailer if you're in the area.
Thanks
My wife found the bins at target.
My propane is mounted on my 4runner, I simply unstrap it and put it next to the kitchen.
I cut the ball hitch with a grinder and then bolted the lock n roll on onto the frame. I think it took one hour to install including painting ground down welds.
I am very interested in your Awning set up, do you mind posting some details. How the rack is made and assembled, how it attached to the roof rack and awning, and why awning you are using?
bueller44
Thanks for answering My questions.
I just installed the awning today. It is from www.shadyboy.com
Parts are built in the USA and assembled in Vancouver Canada.
The awning cover is 49" in total length. And when opened it is 10' wide and 6' deep. I had the aluminum rack custom built at a local weld shop. I then bolted it to the WB deck. It's 1.25" square tube and the sliding part is 1" square tube.
I'll powder coat it this winter to match the black deck. I had it made so that the cross bar that the awning is mounted to can slide in tight for travel and then be moved out when in camp to fit around the tent. I did discover today that rain still runs down the tent onto the kitchen area. Need to figure that out.
The awning can be used without poles or guide lines, if it's not windy.
Here are a few more pics.
I can also use the rack for kayaks or SUP boards. I think I may wire some lights to it as well. Set up at 11 pm in the dark last night. Some led work lights would be great.
I notice you have a bigger tent than mine so you have less deck space. One option would be to raise the tent up about 16" on something similar, but I thought that would be too top heavy. I know taxa is coming up with something for the 2018 WB for an awning. Maybe it will be attachable to a 2017?
Super cool! I wonder if a fabric gutter could be attached to our rain fly's to direct the water away from the kitchen...
wandererr
Damn... so it looks like I will have to buy some raffle tickets after all...
Wandererr... aka Kejtar ;)
Cottontail
Firstly, when the ticket sales begin, we are going to be selling them in person at a number of events, as well as a link on line to purchase. You will have a shot.
Secondly, anyone know for certain what the lug pattern is on this trailer? How big of tires could you feasibly get under it?
Outside somewhere
Overland certified public figure brand ambassador
Looked at one at a dealer in Nc, IIRC they are 5×4.5 No clue if you could go up on the tire. From what I remember looking at one I would say it's probably maxed unless you want to start moving the fenders around.
I know you can fit 235/75/15. You can easily put a lift on the axel by purchasing a #9 axel lift from dexter axel which will give you a additional 2.63” which should be enough for 33” tires.
vertical.dan
