Unimog U430 Earthcruiser Expedition
mark1327
Earthcruiser Explorer 12t
Underbody
▪ 12 tonne GVM
▪ 300hp
▪ Portal Axles
▪ Central Tyre Inflation & Monitoring (CTIS)
▪ Left & Right Hand Drive (10 min change over)
▪ 4 Wheel Disc Brakes
▪ Coil Suspension
▪ 8 Speed Automatic (Including Manual 3min engaging)
▪ 3 Lockers Front, Centre & Rear
▪ Low/Low Working Gear Set
▪ 860l Water - 800l Fuel
▪ Front & Rear 20,000lbs 24volt Winches
▪ 6 Step Electric Entry Steps
▪ 4 Point Hydraulic Jack System (Leveling & Tyre Change)
▪ Heated Tanks, Batteries, Pumps and Water Lines
▪ Front and Rear Snatch points
▪ Anti-starvation, primary filtration fuel pick-ups
▪ Bullet-proof run flat tyre system
Interior
▪ “New” Wider Open Crawl-through
▪ “New” 200mm Wider Body
▪ “New” Control Console
▪ Air Suspension Cab Seats
▪ Double Forward Facing Rear and a single side facing Seats, totaling 5 certified seat-belted seats
▪ Queen Bed or Twins
▪ 212L Double Door Fridge /Freezer
▪ 2 x Sky-Beds, Sleeps 5
▪ Fitted Wet Dry Vacuum Cleaner
▪ Chainsaw and Axe Equipped
▪ Artic System for minus (-40) includes heated water tanks, batteries and drying compartment for clothes etc.??
▪ EarthGrill - 240 Volt outside BBQ, kitchen and sink
▪ Kitchen Caddy with Light
▪ 68L locker fridge
Exterior
▪ Fits inside Shipping Container
▪ EarthAir - Rear Mounted Air Conditioner
▪ Integrated 1600 PSI High Pressure Water Blaster
▪ Large Out-door Screened Shower
▪ “New” Motorbike Lift and Rack
Electrical
▪ “New“ touchscreens that can be intergrated with Ipad or Androids.
▪ “New” Ultransonic Weather station feature incorporated in the touchscreen system
▪ “New” 3 Axis pitch & roll GPS Gyrp Compass feature incorporated in the touchscreen system
▪ Lithium Powered – Equivalent to 17 AGM Batteries (1500 AMPs)
▪ Walk on Mono-crystalline Solar Panels 1000watts
▪ DVR/GPS/4G solid state Celluar Hot spot & GPS Tracking system in real time, 45 Day recording including 5 cameras that can be seen anywhere in the world
▪ 80 Channel UHF
▪ Upgraded Sound system featuring Hema mapping, Bluetooth & Iphone connectivity
▪ 3.2kva Inverter
▪ Master Window & Mirror switching from both the Drivers & Passengers sides
Questor
Huge member
It sure does have all the accouterments.
More than enough electrical power to run a mobile office.
Maybe I'll get to check it out in person some day. I love big rigs like this.
Thanks for sharing with us.
Q~
Sitec
The rear wheel arch lets it down in the looks department... It should have been styled the same as the front arch, giving it a more purposeful look. Nice rig tho.
WonaWarrior
