Sawtooth Unlimited - Off Road Pop Top Camper Trailer
stomperxj
Worked on outriggers and some angle. Video out later this week.
Really liking this build so far. Couple of questions if you don’t mind.
1. General size specs. Exterior height and length.
2. With the top up - interior heights.
3. Are you going to make plan available through your website?
Thanks!
stomperxj
Really liking this build so far. Couple of questions if you don't mind.
Thanks!
Thank you :)
1. Overall height closed 87.5. body length 12ft
2. Interior height closed = 58"~ interior height open (standing area only, sloped top) = 87"~
3. Not sure about plans yet.
I'll decide about plans when this thing is done. Need to finish this trailer and test it out.
Thanks for the info. Won't fit in the garage at 87”. But i wouldn't let that stop me. Looking forward to further development of the build.
Thank you :)
stomperxj
sub'd for this awesome-ness.
Thanks!
What are you using to position your parts for tacking? How are you keeping everything square?
My floor is pretty level. I used 16ga shims on the floor initially. Once it got onto the jack stands I used long pieces of tube and angle clamped across the frame. Everything turned pretty square save for a couple 1/16" discrepancies here and there. I'm happy with how it turned out. I show a lot of frame construction in the video series.
Waters
Thanks!
Right on I'll check out the videos.
stomperxj
Parts!!
Video will be up later this week.
Part #'s
OME CS039R springs
Bal C jacks Model 33231
Bulldog Swivel Jack BD190758
Dexter K23-086-087-00 Brakes
Dexter Brake Hub 84546UC3
Hi Spec S5 15x6 Wheels
vertical.dan
