The Rogue Overland 2012 Nissan Xterra PRO-4X Build
Rogue Overland
Hello all !
You will have to forgive me as I am not always active on the forums but I wanted to share the build on my 2012 Nissan Xterra Pro4X. My goal with this build, which I have done myself since purchasing new in 2012, was to build the ultimate combination of an expedition ready / rock-crawling go-anywhere I want rig
If you would like to follow the adventures on Instagram we are @ RogueOverland
My Photography page is @VegasVuk
The Build List:
Front Suspension:
  • Titan Swapped
  • PRG Upper Titan Control Arms
  • Factory lower titan control arms custom boxed
  • SAW Race Runners w/ Eibach 650lb springs
  • Sway bars removed
  • PRG outer heim tie rods w/custom inner tie rod
Rear Suspension:
  • Alcan 3.5" + 650lb rear leaf packs
  • Bilstein 5125 rear shocks
  • Sway-bars removed
  • Nisstec rear shock protectors
  • Nisstec U-bolt flip kit
  • Custom modified timbren bump-stops
  • Extended brake lines w/custom e-brake cable mount
Drivetrain:
  • 2012 M205 Front Differential w/ ARB Air Locker
  • 5.13 Re-gear
  • M226 ARB Air Locker with custom D44 axle shafts
  • ARB nodular iron rear diff cover
  • Dan's driveline custom made double carden rear drive shaft using spicer 1310's
  • Custom made front driveshaft
  • Factory nissan titan front CV-Axles
  • JWT Performance clutch and Flywheel
  • PRG Short-Shift Kit
Powertrain:
  • Bully dog tuner
  • Borla Stainless cat-back exhaust system
  • Airflow snorkel w/Volant modified air box (fully sealed system)
  • Airaid TB spacer
Electronics:
  • Dual battery system using the following components
  • Optima red-top
  • Oddessy gel cell motorcycle battery
  • battery isolation switch w/monitor
  • dual rear-vehicle mounted battery posts w/gauge
  • rear Edison power strip accommodating an additional 150amps w/usb output
Lighting:
  • Aurora roof mounted 30" LED Bar
  • Amazon 20" curved front bumper mounted LED bar (downgraded 08/2017)
  • OffroadGorilla LUX Rock Lights x 4
  • Amazon specials led cube rear bumper mounted LED's
  • ZAMP Solar LED Awning light bar kit
Wheels/Tires:
  • Level 8 Motorsport 16" Bully Pro Wheels
  • 315/75/16 (35") BFGoodrich K02 All-Terrain ( Added 05/2018)
  • Spidertrax 1.5 " Wheel spacers
The Armor:
  • Hefty Fabworks Front and Rear Bumpers
  • Hefty Fabworks rock sliders
  • Hefty Fabworks full aluminum skid plates
  • Custom built rear corners that tie into the frame utilizing 1" .120 wall tubing all custom bent and welded
Exterior Gear:
  • GOBI stealth series roof rack
  • GOBI rear ladder
  • CVT Mt. St. Helens Hardshell Tent ( UPGRADED 08/2017)
  • ARB 79" Awning
  • Custom mount ROTOPAX setup allowing for 10 gallons of fuel and 6 gallons of water to be carried
  • Trash A ROO !
Recovery Gear:
  • Smittybilt 10k X20 Winch with/syn line
  • Factor 55 Pro-Link
  • MaxTrax x2 / Bubba Rope !! (Added 08/2017)
Interior:
  • Custom interior storage system
  • raingler netting
  • OBA unit w/compressor
  • Sweet LED lighting
  • ARB 63L Fridge w/slide
Misc:
  • No body Lift
  • Btech 2m Radio w/Diamond h770b whip
  • CB Radio w/firestik whip
  • Lots of love and money
  • OverlandSolar 60W System (05/2018)
Thanks for reading !
-Andrew
http://www.rogueoverland.com
http://www.andrewjphoto.com
Dmski
Great looking truck man! I've seen this on Instagram and have to say its one of my favorite xterra's out there.
Rogue Overland
Look's great! Could you add pic's of the rear? I would be interested in seeing that if possible.
Yes- just realized there are none, here are a couple different ways I have run it - always changing!
Wow thats one heck of a build...
Titan swapped , with 35's and properly re-geared.
Thank you very much ! Its been a labor of love, started with the 4.56's and found the 5.12's to be perfect with the manual
Thank you !
Rogue Overland
Some new snaps from the past few months adventures - updated a couple minor build items as well and added a on-board solar setup from Overland Solar (y)
WonaWarrior
