Custom snorkels
W0lfpack91
Does anybody know of any companies that will take custom orders on vehicle snorkels or possibly one that makes one that will fit or adapt to a 1990 ford f150/bronco. Ive done DIY PVC snorkels on similar trucks before but If possible I want a Much nicer looking system on my Bronco And would rather not go the PVC route.
Sent from my SM-G955U using Tapatalk
B
BPD53
Guest
I'm also interested in a custom snorkel. I can't find anything for my truck and would like an aesthetically pleasing design as well.
downhill
Build your own! There are sources for parts on Ebay. There are sources like this :http://www.intakehoses.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=ITN
You can build a very durable and nice looking system using this stuff. Donaldson makes an excellent top pre-filter called the TopSpin, if you want that sort of intake. I built a snorkel to suit my needs for under $50. It actually takes air from a shrouded area in the cowl. It is all the snorkel I need, and it is stealth.
Bullseye240
You could design and build one of your own out of fiberglass. Get/make a hot wire cutter and either find styrofoam blocks or glue them up from sheets. Carve our your design with the hot wire cutter and use a rasp and sandpaper until it is the shape you want it to be. You could do a two piece mold from that to make several more or cover in fiberglass and melt out the foam with acetone. You now have a custom snorkel to your dimensions just add or make a top for it.
Deleman
