Cletus' 2002 Tundra AC Build
Cletus26
Got all the old parts out. Removed the factory hangers and have started cleaning up the frame for a coat of POR15. Only semi-tricky part of the whole process was removing the old bilstien shocks. Ended up grinding the shafts on 2 sides so I could use a crescent wrench to hold it while using a wrench on the top nut.
Now to finish cleaning up the frame. Very tedious work but will look and last much better once recoated
Cletus26
Continued to clean up the frame for POR 15. Drilled the 4 new holes (2 per side) for the shackle flip kit and test fit the bracket
toyick
I build Boat Anchors
you should buy my shocks for your shackle flip kit! the icon cdcs would work great for what your doing.
Trucks looking great btw!
edit just saw you got foxes.
blahhhhhhh
Kpack
Are you going to cut the bedside for the rear bumper like lhanson did? It looks like the Addicted Offroad bumper leaves the bedside untouched.
Cletus26
I am going to cut the bedsides. Both are wrinkled pretty good on the bottom from wheeling. Still deciding how much tho. Torn between angling down to maintain the full flare and mudflap or cutting strait back like the brute force fab bumper (but out of tube). I’m leaning towards strait back and incorporating a removable/position indexing mudflap so it would be open during off-roading
Cletus26
After looking more closely I feel this will be the cut I make (remove all of the tape). Leaves 1 more clip for the flare than going straight across. Still gains over 4 “ Behind the tire and well over 6” at the back.
Subspd
Subbing on this one... I agree too on the rear fender cut line. The angle will serve the purpose needed and look good.
Cletus26
Looking forward to it! Post pictures of the process if you can. I have a set of leafs I need to install and I'm considering doing a U-bolt flip at the same time.
Sorry for the lack of pictures. As for removal it’s all straight forward as long as the bolts aren’t seized in the bushings. I was lucky and everything unbolted nicely. I only tried one nut on the u-bolts and it didn’t budge so i cut them all off. It’s suggested to never re-use ubolts anyway and with the flip kit it uses different style bolts too. What kind of leafs are you installing?
tyv12
For the bedside cut I left the cut 1/2" long and folded it under with a body block and hammer and it allowed the box to keep its regidity rather than being floppy
Cletus26
How well did the paint hold up?
toyick
That’s exactly where i cut mine as well.. for the exact same reason! im diggen your truck.. did u do the sua leafs or the spring over setup?
blahhhhhhh
Cletus26
blahhhhhhh
Spring over deaver expedition pack designed by Jose/Archive Garage with Archive Garage shackle flip kit and ubolt flip kit
GoodEnoughforGabe
Sweet set up! Can you enlighten me on how you attached the quickfists in the bed for the fire extinguisher/shovel/hi lift? Did you just run a bolt through the bed? How do you like the placement? How's it holding up? Thinking about doing the rear storage build myself but want to hear your opinion on that solution for the bigger objects.
Thanks
Deleman
