DIY Composite Flatbed Camper Build
Terra Ops
The response from Stark is entirely consistent with their position that they are selling a "drop in" lithium battery and since the DC-DC converter is doing more or less what an alternator does (only better), it makes sense that they see it as compatible.
What is missing from this response is a statement saying that their BMS disconnects the battery from charging at somewhere between 14.0 and 14.6 volts and re-connects charging at ~13.3 volts (below the resting voltage of a fully charged battery). Unless you are stopping charging once the battery is full, you are slowly damaging it. "Float" charging should never be done with lithium (disturbing to see the CTO endorse it). Keeping it at 14.5v whenever you are charging is damaging the battery. Their 15.2v cutoff (3.8v per cell) is appropriate for protecting the battery from immediate damage (if for instance a voltage regulator somewhere in your system fails).
All that being said, you've got good batteries there. I would just spend the extra couple hundred bucks adding in a proper control to turn the charging on and off unless you can get Stark to say their BMS is doing that at the approximate voltages referenced above.
Sorry, feel kinda like your thread is getting hi-jacked here on a tangent - I'll go back to silently enjoying this cool build :coffee:
No need to be sorry, this is good info. Hopefully we can get a plug and play design that DIY'ers can use.
Terra Ops
I posed this observation to Stark's CTO once again. Here is his response;
The reader is correct that keeping a charge voltage on lithium cells does stress the cell and deteriorate them. Other lithium chemistries used in laptops and cell are more prone to this. LiFePo4 does have a deterioration effect but not as great as other lithium chemistries. In a perfect control environment we recommend to charge to 14.6V then hold a float at 13.8V . Our BMS does not disconnect and reconnect the charger.
In your case, if the DCDC charge to and holds at 14.5/6V that can work. The deterioration will not be that great. Also, I'm assuming the DCDC will not be on 24 hrs every day.
I think the last sentence is key to what is being said.
lostih
Could you post some more details about your pass through? I'm working on figuring that out in my cab now. Was yours factory rear captains chairs?
Terra Ops
Pass through was installed/created by Rob Rowe at Phoenix Custom Campers.
The rear captain seats I did myself. The rear bench comes as a 60/40 split. I kept the 40 and purchased another 40 assembly through
the dealership. Not that hard to do. From my experience, Ram may be the only truck in which you can do this. Cost was less than $1000.00.
Several years ago when purchasing our Tiger, I think Ford was charging 6K for two rear captains.
If I were to do this myself, ... first you need a frame to install into the rear wall that will accommodate the boot or whatever method your using. Remove the glass and save as template for aluminum replacement. Cut rear wall to fit frame. Fill in remaining space with aluminum sheet. I would think you could use the Sikaflex 252 to bond and make water tight. Just my thoughts, proceed at own risk :)
WYCamper
Nice build!
Do you have any idea of the final build weight and center of gravity of the camper?
Also do you intend to have any roof rack or other attachment to the shell and what determined the use of Titan jacks?
CoyoteThistle
In your case, if the DCDC charge to and holds at 14.5/6V that can work. The deterioration will not be that great. Also, I’m assuming the DCDC will not be on 24 hrs every day.
Thanks for posting this! I think it is the most straightforward answer I have seen from a "drop in" lithium battery seller on how their system is working.
Yes, I agree that the last point is key too and something I hadn't been considering. Assuming your daily use is close to your 250ah bank capacity, with a 40amp charge rate you won't be in the "overcharge" zone very often even if you're driving all day.
Stark's answer though is important for other folks out there who are dropping these batteries in to systems designed for lead acid. The way their BMS is working, it is not protecting the battery from typical float charging profiles from shore power converters, solar or whatever folks might be tempted to leave on 24/7 to keep the batteries "topped up". Doing so would definitely damage these batteries.
btw, that pass-through is super cool!
Terra Ops
Nice build!
I'm guesstimating the final weight around 1500lbs. No clue on the center of gravity; all heavy components are deliberately as far forward
as possible for this reason.
I'll have solar on the roof but no plan for roof rack as of now. I've had racks in the past that I just don't use. I have contemplated a type of roof top
tent for additional sleeping.
Jack selection is due to familiarity. I'm currently using them on my other camper and I like the electric lift. What other type of jack might be used?
Terra Ops
I've been very impressed with Stark so far. It will be interesting once the batteries arrive and everything comes together. I think Diplostrat makes an interesting point about voltage and current; REDARC is a well established company with a very good track record. Using two of their chargers, I can confirm that they work as advertised with Lead Acid. Lithium is a whole new world but I suspect that what they are doing will work. Within limits, voltage and amperage are reciprocals - so keeping the voltage high while killing the amps has the same effect as dropping the voltage. Just depends if they have done it properly. Also depends on what is sold in the Australian market.
Worth noting that feeding a lithium battery 14.Xv is not a problem as long as you stop, or cut the amps, when the battery, not the charger, hits just over 14v. These are the voltages for most commercial available "plug and play" "12v" LiFePO4 batteries.
Looking back at post #106, REDARC seems to be giving the battery what it needs. This setup should give me the space and weight savings that I'm looking for. Guess we'll see how it comes together:)
Terra Ops
Odds and ends;
Original plan was to locate the propane tank under the flat bed in one of the boxes and use a
quick connect. Decided against this and went with interior placement. Instead of a large access door, a small
access door to allow easy on off and meter read. Compartment built to isolate and insulate tank from rest of living space.
Small vent installed in case of leakage.
Found some peel and stick vinyl at Home Depot for about $30.
Here is the REDARC in comparison to the inverter. Should be a nice fit.
Terra Ops
Lithium batteries have arrived
I've also been looking for a Norcold ACDC fridge. They are self venting so no cutting into the camper. I have one in our pop up
and have been very pleased with it.
Came across "Truckfridge" at Westy Ventures. http://westyventures.com/parts.html
Here is their description;
" No more worries about propane or keeping the old Dometic fridge lit, concerns of spoiled food (or warm sodas or beer!). These modern fridges, the Truckfridge and Vitrifrigo (basically the same fridge with different trim level) both use the excellent German-made Danfoss compressor system, superior to and less vibration and noise than the 'swing' compressor used by Norcold and other companies. The compressor operates silently - the only thing you hear is a small cooling fan when the fridge is running! There is an interior light that automatically turns on when the door is open; the fridge operates on 12 or 24 volts, 115 and 230 volt with the optional AC function. Current draw on 12 volt is 2.5 amps (average) with an average daily usage of 25 amp-hours. That means it will normally run 2+ days on a 100-110 amp-hour deep-cycle battery. The fridge has a real freezer section with a door to retain the contents. The main door is reversible and has a squeeze-latch (TF) or slide latch (VF) in addition to a magnetic perimeter seal. The door easily allows matching laminate panels to be installed in place of the supplied black panel. Also available are stainless steel door and frame models from Vitrifrigo, for about $150 extra. Two (2) year warranty on cooling system defects, fan, electrical and 1 year on interior and trim."
They no longer sell the Vitrifrigo.
Quality and price are right so I ordered a TF130 ACDC.
More details here at Truckfridge; https://www.truckfridge.com/tf130acdc/
Terra Ops
vertical.dan
