1999 Freightlinerl Ambulance/Camper Electrical issues
rlrenz
My right turn signal became intermittent - I finally figured that my turn signal switch was worn out. A new $68 switch solved the problem
Ozrockrat
I have had to replace the turn signal switch in 2 out of 3 of our Freightliners.luckily they are relatively cheap. But it was for the wipers on the later truck not indicators.
rlrenz
I had taken the old switch apart to see if there was something obvious that could be repaired, but it looked like a worn plastic part was the problem, and at that point, a new switch was the simple solution.
DanoWall
